power steering lines.....help!!.....
Old May 14, 2005 | 03:16 AM
83sd's Avatar
83sd
i am about to place an order for my truck through lmc truckm,i need to replace the lines that run from the ram to the box that the ps pump connects to.(the one with all four lines running to it) the only lines i can find are the return,pressure,left turn and right turn hoses. i think its the left and right hoses but im not too sure. can anyone help me with this?
Old May 14, 2005 | 04:07 PM
83sd's Avatar
83sd
bounce...
Old May 14, 2005 | 05:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
Call LMC customer service.
Old May 14, 2005 | 05:59 PM
highboy's Avatar
highboy
left turn and right turn hoses both go from the valve to the ram. the pressure and return hoses go from the pump to the valve. i'm pretty sure this is correct
Old May 14, 2005 | 07:36 PM
CrazyAirman's Avatar
CrazyAirman
Looking at mine, this would be correct.
Old May 15, 2005 | 05:52 AM
docholiday72tx's Avatar
docholiday72tx
83SD, I highly recomend not even messing with LMC. Call Jeff's Bronco graveyard. I'm sure they will have the correct parts, as well as fair pricing. I also know their quality of parts is way better than LMC and in most cases the prices are way lower. As an added bonus they have a very knowledgable technical staff that can answer all your questions.
One last thing...JBG is a site sponsor. LMC is not. It's not very good to go to a competitor to get information.
Mike
Old May 15, 2005 | 01:14 PM
hatemakings/n's Avatar
hatemakings/n
Where does the line that comes directly out of the back (center) of the pump connect on the valve? Is it the left front port or left rear port? <---Directions taken as if sitting in truck.
Old May 15, 2005 | 03:22 PM
CrazyAirman
That would be the High Pressure line, and it goes on the left rear ( as you are sitting in the truck) The return line is on the right rear. Also, looking at mine, the fittings are different sizes, so it would be hard to mix them up.
Also, as a side note, I have spent money with both LMC and JBG, and have been satisfied with both companys for product, and service. I personally would recomend JBG as a first call, good people, good stuff, and they help keep this site up and running, but if someone else has what you want/need, then go for it!
Old May 15, 2005 | 04:03 PM
KenB's Avatar
KenB
Just a thought.
Take your hose assembly to an industrial parts supply house, or farm and tractor repair shop, or any of many auto parts places now- let them make a matching set up for you.
Old May 15, 2005 | 10:25 PM
83sd's Avatar
83sd
i placed my order through lmc because i already knew alot about them. i will look into jeffs bronco yard. as for our sponser ,everytime i tried to look through their parts i got a page error. i ordered them and im gonna try to get my truck together within the next month. i tried to have them made at a hose supply and they said they couldnt make them because they had to many bends. THANK YOU ALL SO MUCH FOR YOUR REPLYS!! youve been a big help
Old May 15, 2005 | 10:45 PM
plowpusher's Avatar
plowpusher
I went to the local autoparts store had em the nextday out of there local wharehouse so easy walkin look at the book buy these trucks are old but a lot of parts are still available locally don't go to the wax and filter type auto store go to a jobber store napa carquest bumper to bumper go to the place your local repair shops go
Old May 15, 2005 | 11:31 PM
83sd's Avatar
83sd
i work at autozone and im not able to get them through there and i had called napa but they didnt have it either. i already placed the order for the lines,a glove box,the left and right rear e-brake cables,new radiator cap,new pcv valve,and sum other little things. i just did the front brakes on it and i think im gonna do the rears before i put it on the road. my discount at autozone makes a big difference. plus i can cut my drums for free.
