Turn Signal Problem
Old Apr 13, 2000 | 06:42 AM
Bill C.'s Avatar
Bill C.
Turn Signal Problem
Turns out I'm one of those idiots I point to on the highway driving with his blinker going!
I have an '86 F150. When I make a right turn the turn signal works fine and resets itself after completing the turn. However when I make a left turn the signal does'nt reset and I don't always catch it (thus the first sentence in this post (: ). Anyone know what causes this, what the fix is and about what it will cost?
Thanks.
Old Apr 13, 2000 | 07:54 AM
Rob88's Avatar
Rob88
Turn Signal Problem
Sounds like your turn-signal cam is not working properly. You'll have to pull your steering wheel to take a look. I had the problem with the turn signal not staying on during a right hand turn. Tried to replace the cam with an aftermarked one by HELPS --- did not work, and a waste of about $8. Ended up replacing the whole turn-signal/tilt apparatus for $125 from the ford dealer.
Your problem may be different, but by pulling the steering wheel, you can see why the cam is not disengaging after a turn.
Hope this helps.
Rob
(1988 F-150 4x4 302/AOD)
Old Apr 13, 2000 | 08:42 AM
kioolt's Avatar
kioolt
Turn Signal Problem
It sounds like your turn signal cam has one of the tabs broke off. You'll have to pull the steering wheel to fix it.
Old Apr 13, 2000 | 10:57 AM
Pastmaster's Avatar
Pastmaster
Turn Signal Problem
