Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
high jack stands
Old May 12, 2005 | 10:08 PM
95f150's Avatar
95f150
high jack stands
Anyone know where i can find these? They need to be at least 3 feet tall to support my frame rails. I have a 4" suspension lift on a 95f150 4x4. Any links?
Thanks fellas
Old May 12, 2005 | 10:16 PM
oldhalftons's Avatar
oldhalftons
harbor freight 12 ton stands are about that tall
Old May 12, 2005 | 11:00 PM
95f150's Avatar
95f150
probable expensive too eh?
Old May 13, 2005 | 06:31 AM
Ian F's Avatar
Ian F
Depends on what's expensive to you. $85 doesn't sound too bad to me, given the price of steel these days... And 30" maximum height is pretty tall... about the height of the desh I'm sitting at right now...
http://www.harborfreight.com/cpi/cta...emnumber=34924
Old May 13, 2005 | 05:07 PM
95f150's Avatar
95f150
i need something taller than that cause im always doing front end work on my truck and need the frame rails lifted and supported to take the wait off the axles/suspension. My highlift jack only goes 36" and it barely takes the frame up off the ground.
I dont like working under a truck when the suspension/frame is being held up there by a maxed out jackall. Thats why im looking for tall stands.
Could a guy get these made to fit my needs and still be safe?
Old May 13, 2005 | 08:13 PM
Percy's Avatar
Percy
You know - for about $1500 you could probably have a lift installed in your driveway! That ought to give you the lift you are looking for an probably about the safest...
Old May 13, 2005 | 08:47 PM
95f150's Avatar
95f150
lol, that would be nice but i cant see that happening anytime soon.
Old May 13, 2005 | 09:03 PM
Percy's Avatar
Percy
Yeah, I can't get the landlord to go for the pit installation in the garage - either.
Old May 13, 2005 | 11:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Try these 18T stands:
Model: RJS-18
Manufacturer: Ranger Products
Weight: 160.00
Item # 118011
# 18-ton capacity
# Portable design
# Sold in pairs
# Adjustable support tubes with multiple
# locking heights Quick release locking pin
# Steel cradle pad secures load
# Heavy-duty steel construction
# Maximum height: 53” / 1320 mm
# Minimum lowered height: 30” / 762 mm
# Shipping weight per pair: 160 lbs. / 72kg
Price $153.00/pr
Old May 13, 2005 | 11:20 PM
95f150's Avatar
95f150
Thanks, Torque1st
Those babies will work great!
Old May 14, 2005 | 04:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Some more of the same type:
http://www.americasprideonline.com/S...4-.ViewProduct
Similar:
You can find more with the google search: "garage shop equipment"
