89 overheating when accelerating
Old May 25, 2005 | 07:40 AM
95X15's Avatar
95X15
One more thought - if you have a smooth hose on the lower radiator connection, make sure there is a spring inside. The spring prevents the lower hose form collapsing under suction from water pump at higher engine speeds.
Have no idea about cost of engine work - sorry.
Old May 25, 2005 | 08:25 AM
Fords4Me's Avatar
Fords4Me
Thumbs up
Excellent advice.
Old May 25, 2005 | 08:48 AM
Heavy460's Avatar
Heavy460
Try connecting the two coolant hoses going into the heater coil.See if that helps.
Old May 25, 2005 | 02:40 PM
azwolfman's Avatar
azwolfman
Originally Posted by Fords4Me
It could be a head gasket issue. If the gasket should rupture between the cylinder and the water jacket. I have seen it where it is only a slight leak and there is no flow into the cylinder as the pressure in the water jacket is far less. However there is usually some foaming of the antifreeze.
IMO the first thing you should do is to pressure test the cooling system. Thats the only way to find out if the system is truely sealed up like it should be.
If it passes that test look for a water flow issue.
O.K. let's start from the beginning. the truck sat for 1 year after minor front end wreck. Radiator was replaced, filled, and the truck sat for a year. I replaced front clip, battery, plugs and wires, filters, oil, rotor, dist. cap, and a few others. Truck starts and runs good, lots of power. Idles smooth, no missing. No smoking, no oil in water, no water in oil, no odor of coolant, Top and bottom hoses new, bypass hose new, tsat 195 deg new and installed properly, fan clutch (extreme duty) new. Start engine and sit idling - overheats in ten minutes with outside temp around 100 deg. Start engine and drive up the mountain - overheating about the same time maybe little faster. Starting engine from cold, about ten minutes stat opens pressures top hose and it gets hot, and with rad cap off water will flow steady out of rad mouth ( not spurting just steady flow). Removed water pump last nite- it looks like new, turns free. I flushed through rad, then through heater core hose coming off water pump. Flow was good through rad and through core and engine . Flushed till I saw clear water. I'm going to put everything back together tonite and see what happens. But I dont have much hope. Sorry so long but just figured I'd put as much info out as I could.
Old May 25, 2005 | 05:40 PM
Popa Tim's Avatar
Popa Tim
What leads you to beleive you are overheating, what symptoms do you have besides the guage? The guages are not the best quality and can be bad.
Did you bleed the air out of the system? (I'm not sure if you can on your year truck but worth looking into)
Which coolant are you using? Is 60/40 ok for it? The preston I used last says it has to be 70/30 minimum. Also if you didn't drain the block of water and put in the mix then you are way under 60/40. The block on my 5.o will hold almost enough for me to use prestone straight and end up with a 70/30 mix
Do you know if any radiator stop leak was used? Like Bar's maybe?
Is the clutch fan kicking in and spinning in the correct direction to draw air inwards?
(I've seen fans put on backwards....)
When you had the water pump out, you said it turned freely but did you verify that it was actually turning the inpeller? I've seen some old dodges where the impeller broke free, it looked fine but didn't turn if you held it and turned the shaft.
Old May 26, 2005 | 09:37 AM
Fords4Me's Avatar
Fords4Me
Check out the 3rd post.
https://www.ford-trucks.com/forums/s...d.php?t=375870
Maybe try a kitchen thermometer in the radiator cap opening. Most of mine went bad where they showed cool, but it happens.
Just see if the retun water really is that hot.
BTW what engine do you have? You mentioned a bypass hose so i guess it's not an I-6. Did the truck get run after the new radiator was installed? Are you sure it is the right one?
If you had a 460 using a small block non A/C radiator, that would do it.
Old May 26, 2005 | 07:48 PM
azwolfman's Avatar
azwolfman
Popa Tim , I noticed while standing in front of truck hot air was blowing on me. I removed the fan, it was on correctly but I turned it around anyway. It blew out the front even harder. The fan rotates ccw looking at it from front of truck. I have flushed with Gunk rad flush and measured coolant/water ratio to 50/50.
Old May 26, 2005 | 08:03 PM
Popa Tim's Avatar
Popa Tim
which engine do you have?
Old May 26, 2005 | 09:03 PM
azwolfman's Avatar
azwolfman
[QUOTE=Popa Tim]which engine do you have?[/QUOTE
1989 f150 xlt supercab 4x4 with 5.8l efi, auto trans.
Old May 27, 2005 | 09:03 AM
Fords4Me's Avatar
Fords4Me
I think my 88 turns clockwise.
Turning the fan around it will still blow the same direction, you just change efficiency.
Old May 27, 2005 | 10:15 AM
i1dery's Avatar
i1dery
Maybe after sitting there for a long while you have rust sludge
diposites in the block which would allow water to flow but not
in the areas that may count, just a suggestion for ya.
Old May 27, 2005 | 11:16 AM
azwolfman's Avatar
azwolfman
Mine turns counter-clockwise because of the belt configuration. I understand some of the newer fords turn clockwise. I would think the 88's and 89's should be the same but seems like they change things every five minutes.
Old May 27, 2005 | 11:40 AM
  #28
Fords4Me's Avatar
Fords4Me
That's from memory. The truck is 65 miles away. But it seems clockwise.
Either way, you should feel air being pulled into the grill from the front.
Old May 27, 2005 | 02:11 PM
  #29
azwolfman's Avatar
azwolfman
Yeah, I can't believe I didn't catch this for a couple of weeks, but I look on the good side. I've completely re-worked my cooling system now so I shouldn't have to worry about that for awhile. This is really a good lesson for everyone, especially non-mechanics like me. Always, always, always check ALL the simple things first. I think I'll sit down and create a new thread explaining everything from start to finish so maybe I can keep someone from having the same problems as I did. Thanks, everyone, for all the help.
Old May 27, 2005 | 07:35 PM
  #30
Popa Tim's Avatar
Popa Tim
I'm really looking forward to what it was...
belt on wrong?
