Mustang intake improvements?
Old May 12, 2005 | 02:40 AM
bootie's Avatar
bootie
can any one give me any pointers on improving the flow ofmy intake manifold - its is off a 88 stang -
Old May 12, 2005 | 08:49 AM
ronclark's Avatar
ronclark
Why do you want to improve the intake flow? It will already out flow your heads and making it flow more will only kill your torque.
Old May 12, 2005 | 02:26 PM
bootie's Avatar
bootie
well thats a good thing - was worried it wasn't gonna keep up with my clevo heads - just looking at those monster intake ports on the clevo compared to the mustang manifold -
Old May 12, 2005 | 02:44 PM
ronclark's Avatar
ronclark
what are clevo heads? If you are talking about cleveland style heads then your 302 intake isn't going to bolt up and you shouldn't be using the 4 barrell heads if it did. They have absolutely no low end torque on a 302. When used on the boss 302 they would screem once you got the rpm up but were dogs at low rpm.
Old May 13, 2005 | 06:31 AM
bootie's Avatar
bootie
i'm using adaptor plates - courtesy of pricemotorsport to adapt the windsor manifold to my clevo heads - they are the 3v chi heads (basically fully ported 2v aussie heads)
Old May 13, 2005 | 06:32 AM
bootie's Avatar
bootie
can't forget the 2 t04's hanging from the exhausts
Old May 16, 2005 | 01:20 PM
ronclark's Avatar
ronclark
Are these heads already drilled for water flow through the intake? Stock type cleveland heads don't flow water through the intake and you need to drill a 1 in hole in the head for water flow.
Old May 16, 2005 | 02:26 PM
bootie's Avatar
bootie
nope have to be drilled
