General Automotive Discussion
Help, this is driving me NUTS!
Old May 11, 2005 | 11:55 PM
351M's Avatar
351M
I just changed the oil pump in a 93 Tempo, 2.3L etc. Now the problem was that the pump would work then just stop, I put a new pump in, the shaft and everything els looked ok, fired it up, ran good for like 1/2 an hour, fired it back up got about a mile and a half and the oil light came on, same problem again only the old pump would only work for about 5 min if that. Bad part was that I had to shut it off, coast, fire it back up and coast some more for about 3 miles to circle back around. Even worse a cop turned behind me and followed me for a bit. Any ideas what could be wrong? My best guess is the distributor shaft where the oil pump drive slides into is screwed up.
