Fast idle adjustment
Old May 11, 2005 | 07:51 PM
Gouber's Avatar
Gouber
I have a 1979 351m with a 2150 2 barrel. dose any one know if the fast idel speed adjusting screw must be on the V of the fast idel cam, or go past it?
Old May 12, 2005 | 09:11 AM
jtmerritt's Avatar
jtmerritt
I am assuming you mean the fast idle cam of the choke system? Don't know what you mean by on the V or go past it. Cam has multiple steps from low to high. Usually the fast idle speed is set using a tach on the highest step of the cam.
John
Old May 14, 2005 | 03:59 AM
fmc400's Avatar
fmc400
MSEE
He is talking about a V that is etched onto the fast idle cam. With the choke snapped shut, hold down the choke pulloff piston so that the choke opens slightly. While still holding, open the throttle a bit and the cam will drop a tad. Let the throttle back down, let go of the pulloff, and the screw (or cam follower) should be resting right on the V.
Thorncreek
1983 - 2012 Ranger & B-Series
34
Feb 2, 2025 03:11 AM
elraido
Aug 27, 2014 02:36 PM
fordman1986xlt
Mar 3, 2013 04:25 PM
ihdiesel
17
Oct 7, 2008 01:43 PM
cjbronco
Aug 21, 2005 12:58 PM
