360 question
Old May 11, 2005 | 07:41 PM
70_f100's Avatar
70_f100
360 question
Is a 360 internally balanced? The 360 in my 70 f100 has a bad vibration problem. My grandpas flatbed has an identicle 360 and it is one of the smoothest running engines I have ever heard. I would like to get mine at least a little better before it rattles the truck apart....
Old May 11, 2005 | 08:57 PM
rusty70f100's Avatar
rusty70f100
Yes, the 360 is internally balanced, unless someone messed with it.
Are you sure its firing on all cylinders? It sounds like you've got other problems.
Old May 11, 2005 | 09:56 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Vibration or shake, how bad? Many FE's came from the factory 360's / 390's were shakers and 100% stock. If you changed a convertor, flexplate, flywheel or pressure plate you can end up with a shaker.Damper is small diameter and less likely to shake. Wake up, quality control on replacement parts is all about profit. Starting with a balanced motor and balancing any replacement parts before installing is paramont or live with a shaker / bearing des******. Sorry, truth can be harsh.
Carl....=o&o>....
Old May 12, 2005 | 12:46 AM
70_f100's Avatar
70_f100
Uh, It has been a "shaker" so to say, ever since I got the truck, and I havent replaced any parts that would cause it to do so. It is firing on all cylinders also. Anyways, I believe I will be rebuilding the motor soon so I will have it balanced then. thanks for the input.
Old May 12, 2005 | 10:10 AM
Mike G's Avatar
Mike G
Is this an issue when it's just sitting in the driveway running? Take a look at your plug wires and make sure none are jumping a spark.
--Mike
Old May 12, 2005 | 12:11 PM
"Beemer Nut"
As stated above he is "firing on all cylinders". If it's a small vibration or noticeable shake it should appear coming off idle when into 1650 to 1750 rpm's. A pressure plate or torque convertor swap can cause a shaker due to balance tollerances from manufactures. Had a convertor that shook, added a 1" by 1/4" thick brass washer that threaded onto the convertor stub after the nut to smooth it out before ordering another convertor. Custom made took 3 weeks.
Carl....=o&o>....
Turbo Dog
29
Feb 20, 2017 02:46 PM
Sergio Reta
Apr 26, 2016 09:43 PM
79modified
Aug 10, 2004 06:45 PM
shunderwunder
Mar 15, 2003 06:58 PM
Dick Boyd
Dec 14, 1999 07:03 PM
