OBDII Location
Old May 11, 2005 | 02:46 PM
96DRW's Avatar
96DRW
OBDII Location
Hello everybody - Im going to be getting an OBDII scanner in the near future to use with my 96 F-350. I'm having trouble finding the 6-pin connector on the truck to plug the interface cable into. I've looked around under the dash but nothing looks like the appropriate connector. I know manufactures started using OBDII on all cars 96 and on, so I'm pretty sure it's somewhere. Any help would be appreciated.
Old May 11, 2005 | 03:57 PM
RangerRuss's Avatar
RangerRuss
Usually they are under the dashboard between the steering column and the drivers door. I was asked to scan a Focus two weeks ago and the connector was behind a removable cover on the lower edge of the dashboard.
Anyone else know for sure?
Russ
Old May 11, 2005 | 04:34 PM
chrono4's Avatar
chrono4
i know my 88 isnt obd2 but its under the hood oh the wheel well on the drivers side. just a thought.
Old May 11, 2005 | 05:10 PM
96DRW's Avatar
96DRW
As I was searching the forum for an answer I ran across a post that said Ford did not go with the OBDII on trucks 3/4 ton and above. Anyone know if this is true?
Old May 11, 2005 | 05:46 PM
handyman43358's Avatar
handyman43358
I'm not sure about that, all vehicles were required from 96 and beyond to "have an OBDII connector within reach of the drivers seat." The one on my buddies 96 bronco was underneath the dash... pretty much straight down from the radio but not sure if thats where they all are...
Old May 11, 2005 | 06:22 PM
chrono4's Avatar
chrono4
every car after 96 had to have obd2
Old May 12, 2005 | 01:38 AM
EPNCSU2006's Avatar
EPNCSU2006
Over 8800 GVWR vehicles were not required to go OBD-II in '96. Your truck is OBD and has an EEC-IV computer. Don't spend any money on a code reader; you can read them all with the check engine light. The diagnostic connector for this system should be near the hood spring on the driver side of the truck.
Old May 12, 2005 | 11:34 AM
96DRW's Avatar
96DRW
Thanks for all the help - I looked under the hood and on the drivers side wheel well I have the EEC(?) connector indicating that I do have the OBDI. I want to check for any stored codes myself however, I have a question. The http://www.fordfuelinjection.com/ site looks like it gives some good information about how to do it unfortunately they left out steps 1 and 2. My question is, how to you "jump" the 2 connection? Can you just use a piece of wirel and place each end in the appropriate connector? Do you need to ground anything to the battery? Thanks in advance.
Old May 12, 2005 | 04:13 PM
ronsc1985's Avatar
ronsc1985
It has been awhile since I did this but I'm pretty sure you just jumper the two pins together in the two pin connector.
With respect to code readers for this model (96, 460, drw F-350 which I have) a decent scanner allows you to run quite a few diagnostic checks in ECC IV systems. I used a friends Snap-On box and it found a few things wrong besides the code for the oxygen sensor which neeed replacing.
Old May 12, 2005 | 08:08 PM
EPNCSU2006's Avatar
EPNCSU2006
You can't do anything with a code reader that you can't do with a paperclip, unless it plugs into the J3 service port on the back of the computer.
spudlicker
17
Sep 28, 2016 08:36 AM
Fordman96
Computer Chips & Tuners
Jun 6, 2013 06:19 PM
tazaxx
15
Oct 24, 2012 12:47 PM
FlatlanderKW
Aug 4, 2010 04:18 PM
mbkatt
Jun 19, 2008 07:45 PM
