I-6 engine rebuild
Old Apr 22, 2000 | 07:03 PM
tjhale's Avatar
tjhale
I-6 engine rebuild
I have a 1987 f-150 4x4 with an 300 i-6 with a cracked block. I have an mid 70s block. Are the blocks the same if not what year blocks will work.
Old Apr 22, 2000 | 09:39 PM
PAUL_2's Avatar
PAUL_2
I-6 engine rebuild
The only thing that comes to mind is the location of the mechanical fuel pump ...lower left hand side of the block . I suppose you can fashion a plate and use the fuel pump gasket to cover the hole or leave the fuel pump in place and plug its inlet and outlet ports . Other than that , if the other block is in good shape , the rest should be the same .
Paul
Old Apr 23, 2000 | 11:12 AM
PAUL_2's Avatar
PAUL_2
I-6 engine rebuild
