knock sensors
Old Mar 12, 2000 | 05:47 PM
Pastmaster's Avatar
Pastmaster
knock sensors
Old Apr 23, 2000 | 02:34 PM
80f3504x4's Avatar
80f3504x4
knock sensors
Hopefully somebody won't call me stupid but if your knock sensor was unplugged would your engine performance be poor.
Old Apr 23, 2000 | 03:11 PM
PAUL_2's Avatar
PAUL_2
knock sensors
Basically , the Knock Sensor retards the timing when it detects the pinging for instance going up a hill , anytime the engine is under load . Having it unplugged would prevent it from doing what I have described . What engine are you referring to ? I assume you noticed some pinging ?
Paul
Old Apr 23, 2000 | 03:24 PM
80f3504x4's Avatar
80f3504x4
knock sensors
The engine is 5.0 in a 87 F150. The problem was when my friend put a new engine in his truck we couldn't find out were one electrical connector went. We proceeded in looking at the old block and found the Knock senser still screwed into the block. Therefore is new engine doesn't have a knock sensor. The reason i'm asking is the new engine doesn't perform the way it should. It doesn't make any noises but it just ain't got the get up and go that it should.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
