1978 - 1996 Big Bronco
ignition modular
Old May 12, 2005 | 04:01 PM
Kemicalburns's Avatar
Kemicalburns
hard to say, you should have checked for codes. more an more cranking is usually a combination of things like needing a tune up, timing set properly, fuel filter changed and if that didnt solve anything checking fuel pressure if its low or higher then spec replace fuel pressure regulator . but frankly there is no adjustment to the fpr unless they sold you and adjustable one which shouldnt be used on a stock motor. and for the throttle body spacer those are proven junk .
Old May 12, 2005 | 04:11 PM
jem270's Avatar
jem270
I had already done all the usual tune up stuff including the fuel filter. I forgot to say that they also replaced the coil the first time (I had just put another one on so they took me there also.) What ever they did the second time, it now starts up great. It sounded like bunk to me when they made the statement about the fuel pressure but I’m an old carburetor guy so I accepted it (since it worked). No telling what they did but I wish I knew.
Old May 12, 2005 | 04:12 PM
Kemicalburns
they might have bumped your timing up , i know my bronco starts better at 12* vs the stock 10*.
Old May 12, 2005 | 04:22 PM
jem270's Avatar
jem270
Thanks for the reply. You are probably right. I guess I should not recommend that place to anyone. They were recommended highly to me. I need to remember who it was. Ha. I have just started reading posts on this site and I have learned much about my Bronc. Thanks.
Old May 12, 2005 | 07:20 PM
greystreak92's Avatar
greystreak92
Kem makes a very good point about pulling the codes and running the self-tests FIRST, guys. They really aren't that difficult to get/run and they WILL save you a bundle of money, time, and guessing at the real cause of the problem.
garry11268
Jul 10, 2014 04:38 PM
jerryjerry05
Modular V10 (6.8l)
Dec 5, 2013 06:26 PM
lisagreer
Feb 19, 2008 05:35 PM
eallanboggs
General Automotive Discussion
29
Feb 1, 2008 08:38 PM
Dean88
Modular V8 (4.6L, 5.4L)
16
Dec 5, 2007 02:15 PM
