Sponsored by: Innova
flat powered subs...???
Old May 11, 2005 | 12:25 AM
s2gots's Avatar
s2gots
I was just checking out crutchfield, was looking at a bazooka 6" that might fit behind the rear cc seat on an 04 F-350, and came about to a powered sub that is flat!! I think the dimensions were only 4" thick,and in the description said it will fit under a seat? Kenwood made this perticular one, sorry I dont have the link. Any one seen this before, If so, how do they sound??
Old May 11, 2005 | 12:44 AM
RomerB2's Avatar
RomerB2
I know what you're talking about, but I have never personally heard one. I have heard the Blaupunkt Overdrive subs though.. and they sound really good. High audio quality and they hit hard and solid. But they're pricey. They are made for shallow mount applications though, and are slightly thicker than the height of a AA battery.
Old May 11, 2005 | 12:49 AM
s2gots's Avatar
s2gots
Hey you know where I can get some more info on the one youre talking about??
Old May 11, 2005 | 01:02 AM
RomerB2's Avatar
RomerB2
Crutchfield use to have them, I suppose they still do. But I'll do some research and post some links in a little while.
Old May 11, 2005 | 01:08 AM
RomerB2's Avatar
RomerB2
http://www.crutchfield.com/S-yq4x15KwReB/cgi-bin/prodview.asp?i=023OD1200
There's it with the battery. Looks like Crutchfield does have them.. but they're pricey.
Old May 11, 2005 | 01:18 AM
351M's Avatar
351M
Nice! that thing hits lower than my Polk 10. I was also going to say go to a shop that sells Premier and have a look at the truck subs. Also 12s and also about 4" thick and sound damn sweet.
Old May 11, 2005 | 01:23 AM
RomerB2's Avatar
RomerB2
I really liked it when I was just browsing through subs. If I had the money, and needed a flat sub I would own one.
Old May 11, 2005 | 06:24 PM
1stfordtrck's Avatar
1stfordtrck
2 bad i didnt have the money for those i have 2 12's that are 7 inches deep behind my seat.. lots of chiseling on the mdf 2 get it to fit lol
Old May 12, 2005 | 08:57 PM
Sn0wMan's Avatar
Sn0wMan
Man i would love to buy those if i had the cash, then i could get my leg room back.... Guess ill just stick with my two JL 10's behind the seat. Having a regular cab with a bench is no fun at all lol.
Old May 12, 2005 | 10:12 PM
RomerB2's Avatar
RomerB2
I love my Bronco II for that reason. I have so much room to put subs and amps if I choose.
Old May 19, 2005 | 03:34 PM
Sn0wMan's Avatar
Sn0wMan
Hmmmm i checked and theres another model that has same specs and everything that just looks different, and its 200 dollars (also from blaupunkt sp?). It says that these speakers are for open air application, like a trunk. Now how would i go about putting these behind the bench seat in my truck (reg cab)? Would it be safe for a sealed or ported box, or just mount them to the back of the cab somehow, like a board? Im currently running two JL10w0's and an eclipse bridged 200watt amp. I would probably sell the subs and boxs, use the same amp/wiring.
Old May 19, 2005 | 07:47 PM
351M's Avatar
351M
I doubt the open air subs would sound as good as what you have. They are most likely designed to be mounted so that your trunk is the box. (remove the rear seat and mount the subs to mdf in place of the seat back) kind of like the 6.5" open air woofers in the doors of the '02+ Rams.
Old May 19, 2005 | 09:34 PM
RomerB2's Avatar
RomerB2
Open air subs treat the trunk of a car as their box, it wouldn't work with your truck unless you decided to put a wall up, but you only have a regular cab so that wouldn't work. They should be able to be put in a box, see what it recommends for ported and sealed boxes.
Old May 19, 2005 | 11:01 PM
351M's Avatar
351M
You could e-mail blaupunkt and see what they say.
Old May 19, 2005 | 11:18 PM
RomerB2's Avatar
RomerB2
Good idea.
