Map Sensor
Old May 10, 2005 | 09:09 PM
Medic 66's Avatar
Medic 66
Map Sensor
When I had some work done by the Ford garage, they told me that my "map sensor" was unplugged. I never knew any different driving either way. They plugged it back in for me and it is the same as always....just wondering what a map sensor is for?? Puzzling...............must be like an appedix....just their?
Old May 11, 2005 | 01:26 AM
rockyrider's Avatar
rockyrider
MAP: Manifold Absolute Pressure sensor Strategy and feedback input; The PCM monitors manifold pressure to control fuel delivery in order to minimize smoke. It also optimizes injection timing for detected boost. It also monitor boost to limit fuel delivery to control maximum turbo boost. Frequency output; 111Hz=14.7psi, 130Hz=20psi, 167Hz=30psi. PID: MAP (pressure basline 14.7psi), MAP HZ (frequency), MGP Manifold Gauge Pressure (pressure base line 0psi) turbo boost
Old May 11, 2005 | 02:37 AM
Biwanylo's Avatar
Biwanylo
Cool Thats a lot of good info
Old Jun 19, 2005 | 06:51 PM
djf48's Avatar
djf48
Where would I find the MAP sensor on a 1997 F250?
Old Jun 19, 2005 | 06:58 PM
Quadzilla's Avatar
Quadzilla
It's located on the passenger's side firewall. It can be identified by the vacuum line that's connected to it, which leads to a port on the engine behind the engine cover.
If the original poster couldn't tell a difference in how the truck ran with the MAP line disconnected, I'd have to speculate that it's faulty.
Old Jun 19, 2005 | 08:52 PM
Medic 66's Avatar
Medic 66
How do I test to see if it is indeed faulty.......being that I am the orginal poster and all.
Old Jun 19, 2005 | 09:54 PM
djf48's Avatar
djf48
Is that the vacuum hose that I "T" into for my boost gauge?
Old Jun 19, 2005 | 10:01 PM
Kwikkordead's Avatar
Kwikkordead
This would be a good one for somebody who's good with electronics. Make some sort of circuit with a toggle switch that outputs the idle frequency and the full boost frequency. You could fool the ECU into thinking that it has full boost right away and go ahead and inject more fuel. Put a microswitch on the accelorator pedal to engage it like this:
tommyl
Sep 1, 2014 10:00 PM
Jnowaczyk
Modular V10 (6.8l)
Nov 5, 2013 02:55 AM
Lilpooh
6.4L Power Stroke Diesel
May 3, 2013 02:29 PM
WILLYG247
13
Dec 22, 2010 04:09 PM
oldhampete
Oct 28, 2003 10:24 PM
