Axle Identity
Old May 10, 2005 | 08:04 PM
Semper Fordelis's Avatar
Semper Fordelis
Exclamation Axle Identity
This Truck is made up of a few different trucks.....I need to put in some new gearing and replace a spindle....but I have no idea what type of axles these are. Please check out my pics and let me know what you think they are, Thanks
My Album
Old May 11, 2005 | 01:15 AM
beeboy's Avatar
beeboy
it wanted me to register to see your photos.
Old May 11, 2005 | 02:20 AM
thesprocket26's Avatar
thesprocket26
How many lugs are on the axle? Does it have a removable 3rd member? Have you checked for an axle tag? Did you include more info?
Old May 12, 2005 | 10:42 PM
Semper Fordelis
8 lugs, I have no idea what a "removeable third member" is and I cant find any numbers on it, any suggestions on where I can post these pictures?
Old May 12, 2005 | 11:33 PM
FordPickMeUp's Avatar
FordPickMeUp
why dont you just post the pics on here?i can't see them from your link for some reason.
Old May 12, 2005 | 11:49 PM
beeboy's Avatar
beeboy
Semper, this is a removeable third member.
<img src=http://mustangandfords.com/techarticles/127_0310_diff_sb4_a_k_z.jpg>
Old Jul 26, 2005 | 07:43 PM
Semper Fordelis
lets try again
I have posted some pics of my axles in my gallery finally! Can everyone help me figure out what i have so I can fix it?!
Old Jul 26, 2005 | 08:28 PM
thesprocket26
I'm pretty sure it is a dana 44 front axle. I don't know if it is the HD version or not.
Old Jul 27, 2005 | 04:18 AM
beeboy's Avatar
beeboy
if you have a fast interent connection, you can find out what you have based on the info in this document from Dana
http://www2.dana.com/pdf/X510-2CVSP.PDF
It's a large PDF file, you will need adobe acrobat reader to open it.
Old Jul 27, 2005 | 03:07 PM
ivanribic's Avatar
ivanribic
Kind of weird. That axle SHOULD be a D60 but it's not. From the size of that axle tube it looks like a D44 HD to me. Do you have a picture/measurement of the hubs?
Old Jul 27, 2005 | 05:08 PM
GreenSubmarine's Avatar
GreenSubmarine
I agree with Ivan, I'm 99+% sure it's a 44. Ivan, correct me if I'm wrong, but the guts (r&p, inner axles, axle joints) of the reg 44 and the 44HD are identical; it's the stubs, the spindles and everything outside that are different. So, you need a photo of a locking hub to get a final determination of the axle. That, or can you tell us if it has internal or external hubs?
Old Jul 27, 2005 | 05:20 PM
ivanribic's Avatar
ivanribic
Ernie, I got no clue about the inner workings of the D44 but the tubes look larger than a D44, and while center portion looks like it could be a D60 but those knuckles look like heavy BJ knuckles whereas they should be kingpin if it's a 60. So this is what makes me think it's an HD 44. But hey, I've been wrong before.
Old Jul 27, 2005 | 05:52 PM
GreenSubmarine
Ivan, if you can go look at your front cover bolt pattern. I'm pretty certain that the bolts on the sides of the cover are not exactly vertical on a 60; but they are on this axle. I don't have anything nearby, and I'm too lazy to search online. I think we can vereify that it's a 44 using the bolt pattern.
Old Jul 27, 2005 | 06:07 PM
ivanribic's Avatar
ivanribic
By gosh you're right, let me go check the pattern differences. I'll post back when I find out.
Old Jul 27, 2005 | 06:20 PM
ivanribic's Avatar
ivanribic
Well I'm working out of town but the pics I have of my axle look like the bolts are pretty even so I guess that plan won't work.
