Sponsored by: Real Truck
Question on DR lift
Old May 10, 2005 | 02:27 PM
crashandburn420's Avatar
crashandburn420
Question on DR lift
I have the 6 inch front spring rear block DR lift. I didn't realize until after the install that my rear rides lower than my front. It seems that the retailer sent me the wrong blocks. The blocks that I have are meant to go with the taller 350 factory blocks, not the 250. Is therd any advantage to buying another set of blocks for the 250 from DR vs. finding a set of 350 blocks and using with what I already have from DR? Thanks!
Also, any reason that my truck is lower on the driver side? Over the past couple of months, it is sinking on the driver side.
Old May 12, 2005 | 01:17 PM
uponyou21's Avatar
uponyou21
The blocks would be no different maybe just the price. As far as the drivers side sitting lower the only thing is that your fuel tank is on that side mine sits a hair bit lower when the tank is topped off!!
Old May 12, 2005 | 02:01 PM
DernMooseAk's Avatar
DernMooseAk
There is a thread either here or in 4x4 section talking about the lean. Most fords do, I think they said there was a shim kit to fix them. If I remember correctly ford will do it?
