paint troubles
Old May 9, 2005 | 11:30 PM
shortblock2000's Avatar
shortblock2000
paint troubles
I had my 1986 FORD F-150 painted about 2 yearsd ago with a BASE COAT CLEAR COAT and I have troubles with spots and stains from bugs. If it rains and sits out in the sun and dries even for a day it gets these spots whick looks like go deep in the clear coat and it very hard to rub out even with wax. If bugs hit the paint and stays on just for a day it leaves very very hard spots which wax wont hardly remove with rubbing till your hand goes numb.
does anyone have any reasons what causes this.....bad paint maybe?
suggestions how to clean the spots would be greatly appreciated.
Old May 10, 2005 | 02:19 PM
savage066's Avatar
savage066
rubbing or polishing compound should do it. just don't rub too hard, or you'll go right through the clear coat. as far as the cause, it could be any number of issues with the paint.
Old May 10, 2005 | 03:11 PM
Lazy K's Avatar
Lazy K
Sounds like a problem that affected the early water based paints about four of five years ago. I don`t know what the solution to your problem is.
Old May 10, 2005 | 06:32 PM
big hoss 29's Avatar
big hoss 29
It could also be that the painter didn't put enough hardener in the clear. If you wanted to, you could try taking it back to the shop that did the work and see if they will honor any warranty. If not, the next best thing would be to have them sand off the clear and apply another clear coat.
