backup sensor turns off?
Old May 9, 2005 | 11:23 PM
wipper's Avatar
wipper
so i saw the backup sensor off and tried to turn it on but it just turns off again. what's up?
2001 4x4 with a 5.4
Old May 10, 2005 | 09:13 AM
X 03 Jeff's Avatar
X 03 Jeff
It sounds like a bad switch, try taking it out and doing a continuity test on the switch. That to me seems like the most logical place to start.
Jeff
Old Jun 3, 2005 | 11:00 AM
remlle's Avatar
remlle
I know Im late comming to this conversation but I just found the site.
We had the same issue on our 02 excursion. We took it to the dealer (still under warrenty) and they found a bad sensor on the bumper. replaced and problem went away. we also on occasion found a beeping noise in the car while reversing. the dealer said that was a sign of another sensor going out so they replaced the whole set.
Old Jun 3, 2005 | 03:46 PM
wipper's Avatar
wipper
thank you, i will have to look at them when i get home
Old Jun 3, 2005 | 04:10 PM
remlle's Avatar
remlle
you wont be able to see it broken (or at least I couldnt) it was inside the actual unit.
