Torque Specifications
Old May 7, 2005 | 01:44 PM
1987rangerxlt's Avatar
1987rangerxlt
I rebuilt my Ranger after the head gasket blew a some time ago but never did do the final torque on the head bolts. Does anyone know those specs?
-Jeff
Old May 7, 2005 | 02:22 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The torque spec will depend on what motor you have.
Old May 7, 2005 | 10:20 PM
1987rangerxlt
It's a 2.9L. I just need to do the final torque after driving it 50 miles or something. Or was it 50 minutes?
Old May 8, 2005 | 08:34 AM
Bart99GT's Avatar
Bart99GT
Usually you torque in two steps, first 60 lb/ft, then 90 lb/ft. That holds true for most Ford vehicles until torque to yield bolts came into the picture. Those are usually torqued to 25-30 lb/ft in the first step, then 50 lb/ft plus 90-180 degrees of rotation. Older head bolts can be reused numerous times provided there are no signs of damage or fatigue, TTY bolts can be reused maybe once, although they should be replaced after use.
Old May 8, 2005 | 03:09 PM
Ken00's Avatar
Ken00
22, then 53, wait 5 mins and then 90 degrees in this order...
8 1 4 6
5 3 2 7
The bolts can't be reused, they are torque to yield.
Old May 15, 2005 | 09:48 PM
1987rangerxlt
"Within 5 minutes"
Well, it's been a couple of years so I guess I won't bother with the final torque.
I drove it over the hill into the San Fernando Valley and it held together. But now I'm thinking about changing the gear oil and the oil in the rear end and I guess the one on the front axel since it is four-wheel drive.
Sound good?
