351w from mexico???
Old May 6, 2005 | 10:03 PM
wyatts72's Avatar
wyatts72
351w from mexico???
i went to parts house to get new dist. i took my old one with me and they said it is a mexican 351w anybody ever heard of this before.
Old May 6, 2005 | 10:16 PM
70T351W's Avatar
70T351W
Dude I am not sure but I think they might be blowing you a bunch of hot air. Call the Ford dealer and ask for parts and tell them your info. Did they tell you about the mexican lowering kit that comes with that style of motor?
Old May 7, 2005 | 12:04 AM
Purely Ford's Avatar
Purely Ford
Ford has or had a casting center in Mexico. There are lots of engines that you'll find with a spanish form of Made in Mexico cast into the lifter valley. I think it is Hecho en Mexico. There are other casting numbers or such to go by as well.
Several reliable of sources suggest that these blocks have a higher nickle content and are stronger than other blocks cast here in the U.S.. Maybe someone here has had first hand experience with this and will confirm or discount this.
Old May 7, 2005 | 04:01 AM
luvinfords's Avatar
luvinfords
I personaly seen Mexican 302 & 351W blocks go for a few hundred ...And from all the reading I have done , states that the block is stronger due to the higher Nickel contint, Like Purely Ford says. Check your block and get all of the casting #'s and anything thats written on the block (assumes the block is out) Steve
Old May 7, 2005 | 06:51 AM
70T351W's Avatar
70T351W
Hey, I apaologize I really thought the guys at the auto store were giving you a hard time. I have never heard of mexican cast blocks. Could
auto parts such as bearings and rings fit these castings or would you you have to special order? What ever you hang on to it, it sounds great.
Old May 7, 2005 | 04:35 PM
Purely Ford
The specs on the internal rotating assembly are no different than any other. The final assemble most likely took place here in the U.S. back then. The amount of overbore it'll take to clean up may be different because there may not even be a ridge worn in near the top of the cylinders. That is if they really are made of harder material.
ola1234
Mar 17, 2017 08:36 AM
Garrett Murta
Sep 12, 2016 07:40 PM
upriverjoe
Jul 8, 2012 05:35 PM
v10squirrel
Jul 10, 2007 08:54 PM
95ford4x4cowboy
May 14, 2005 09:30 AM
