1978 - 1996 Big Bronco
Manual trans. swap
Old May 6, 2005 | 01:23 PM
TSBRONCO's Avatar
TSBRONCO
Manual trans. swap
I have a 96' bronco 351w/E4od(I think) I was wondering what All i would need for a Man. Trans swap. I know ill need trans, pedal cluster, master cylinder but will i need a new ECU can i just find a junk F-150 a pull everything.
has anyone done this before ???
Did the bronco ever come with a clutch????
Old May 6, 2005 | 02:29 PM
Kemicalburns's Avatar
Kemicalburns
yes this can be done and has many times. the manual tranny you want is a zf 5speed. i believe you can just use your current ecu with no problems. the tranny wont be found in an f150 but in a f250/350 . you will want all you said above along with the tranny crossmember an if the tcase thats mated to that manual is a manual tcase you might want that to instead of the electric on you may or maynot have currently. Do a search here and on google you will find all you need to know.
good luck
