Meter install
Old May 6, 2005 | 11:12 AM
John Kiernan's Avatar
John Kiernan
Meter install
Just received my Pyrometer, trans temp and boost gages. Directions show several options on install. What is the best way to install ?
Does boost gauge splice into an existing pressure hose with a T fitting or does it have to be connected somewhere in the engine compartment ?
How does pyrometer connect. Do I need to weld in the fitting or is using the stainless strap and hole a easier application ?
Do you have to cut holes in existing pillar plastic to fit wires behind ?
Old May 6, 2005 | 11:37 AM
satcom40's Avatar
satcom40
On my 04 f-250 the boost splice into the the hose, as for the Pyrometer I drill and tap the manafold. And I did not use a pillar mount for my gauges I have boost and pyro build into one unit digital read out. My .02 and Welcome to FTE.
Old May 6, 2005 | 07:53 PM
John Kiernan
Is the existing boost line under the dash similar to my Lightning ? Where do I drill and tap the pyrometer and is access a problem ?
Old May 7, 2005 | 06:57 AM
satcom40's Avatar
satcom40
well on my 04 the Bosst line runs form the intake manafold to the senor to the left side of truck atop of the shock mount and as for the pyro i lifted up the left side of truck and so i can get under it and drill the hole just where the exhust manafold turns up being careful with a little gearse on the drill bit and a vacum and a little gearse on the tap and it when well. hope this helps. John
Old May 15, 2005 | 12:47 PM
John Kiernan
Is the left side when you are sitting in the truck or facing the engine standing outside. Having trouble finding the hose
Old May 15, 2005 | 01:01 PM
satcom40's Avatar
satcom40
As you Look at the engine Sorry about that. John
Old May 15, 2005 | 01:10 PM
John Kiernan
Still having trouble. Hooked into the gray hose and 2 other black hoses. Still no reading on meter.
Old May 15, 2005 | 07:30 PM
The6.0MAN's Avatar
The6.0MAN
John,
The map sensor hose is on the left side of the engine if u R facing it. It is located on the top back side passenger valve cover and comes straight up and bends to the left and ties in to the sensor by the rubber hood gasket and has a black wire tie and split-loom cover over the hose. I used the t-fitting supplied w/ mine but tieing into the map sensor made the turbo guage clatter and vibrate. I re installed the hose and drilled a 1/8 npt hole into the intake elbow and put a brass 90 degree fitting. If U R facing the engine, their is a flat spot on the back side of the elbow. it works perfect and shows 2lbs more boost. there are detailed pics at the dieselstop.com or dieselmanor.com and search for turbo boost guage.
Old May 15, 2005 | 09:20 PM
111900's Avatar
111900
Meter Install Instructions
Check out http://www.dieselmanor.com. It has complete instructions with pictures for installing a 3 guage A-pillar pod and where to connect all of the sensors. The installation instructions are located at: http://www.dieselmanor.com/diy/PSD3-...D3gauge-p1.htm
