engine dying
Old May 5, 2005 | 10:15 AM
rudace's Avatar
rudace
engine dying
i have a 2000 f250 with the 7.3....it's the first diesel i've ever owned...great truck but lately the engine will just die. it usually happens at a low speed or at idle. if anyone can help me i'd greatly appreciate it...thanks
Old May 5, 2005 | 02:03 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Check your CPS, buy it from International if you can, you'll pay about $100 vs. $200 from Ford. Even if that's not it you should keep a spare one on hand. It's a 10 minute swap and a known problem area on these trucks.
Old May 5, 2005 | 02:21 PM
rudace's Avatar
rudace
thanks for the info...but could you tell me appx where this is located...thanks
Old May 5, 2005 | 02:27 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
On front of the engine, about 10 o'clock of the crank pulley if you're facing the pulley. It's a small sensor with a 2 wire plug going to it.
Old May 5, 2005 | 02:29 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
http://pages.prodigy.net/stevebaz/_i...az/index3.html
There's lots of good info on this site.
Old May 6, 2005 | 05:10 AM
rockyrider's Avatar
rockyrider
This will help you!!
https://www.ford-trucks.com/article/...ke_Diesel.html
Old May 9, 2005 | 11:04 AM
rudace's Avatar
rudace
thanks guys....that's what it was...truck running real good now..i also just installed a k&n filter...we'll see how much better it runs...thanks for the info
