Questions about throttle surging ???
Here's what happened:
1) towing the 5'er through the campground with a 10 mph speed limit, low gear and/or first gear, flat paved road, the truck would not hold a constant speed - it kept surging and letting off, and made the truck bounce around, which got worse and worse because you can't keep your foot steady on the accelerator pedal. We had to come to a complete stop and try to start up again, about 6 times to make it through the campground.
2) climbing up a fairly steep, rocky, clayey, wet, one-lane fire road, same thing happened when trying to slowly crawl along in 4x4 high (no trailer). Tried putting it in 4x4 low, and it was no different. Ended up having to run through 4 gears in 4x4 low to about 20-25 mph to get the rpm's up enough to hold steady and seriously fly up the road without surging. (On the plus-side, I'm ready for desert racing now!)
Previous to this truck we had a V-10 manual F250, and never had this problem at all. This is our first diesel - can someone tell me what is going on and what to do to fix it?
Much appreciated!!
~~~~~TrekChick
If the oil level appears to be fine the next possible item could be wire chaffing, although I would think that 2800 miles would be a little early for that to develop. In addition, Ford should have resolved all chaffing issues for '05 MY. But you never know.
Others will surely chime in throughout the day with additional info. Hang in there.
BE
They come from the factory with 10-30 and some of them "romp" when you change them over to 15-40. Our local Ford dealer is advising people to run 10-30 and that is what I would have done if I kept it.
A friend that works for the State Bureau of Automotive Repair mentioned to us about the "electronic throttle" - he said that because it's electronic, it should NOT be touchy (like if it was a lose/tight cable or worn out linkage). That is to say, there should be no "mechanical" reason it's bucking & snorting. "Eletronic" - I don't know about that. He also said he'd look further into this for us, but we haven't heard back yet. Also, it's not just rough terrain making it happen - it happens just driving through the flat grocery store parking lot trolling for an open space, or with the trailer hooked up just trying to go slow. The truck just won't (can't?) run less than 15 mph without jumping around. With the 5'er hooked up it felt like we were gonna shear off the kingpin! I was hoping someone else had gone through this, to the point of actually getting it resolved, and could enlighten us on what exactly to ask be fixed when we go back to the dealer.
Thanks again for everyone's input!!
~~~~~TrekChick
Commentary: Given my 6.0 ownership experience over the past 26 months and 52,000 miles- I have found the dealers (2) to be quite knowledgable/prompt and decisive about troubleshooting and repairing my 6.0 (Although the first month was frustrating). At this point in time, I am convinced of two things:
#1 A lot of the intial "trouble" with the 6.0s were directly related to poor (no)Tech training offered by FoMoCo combined with a few flash/program glicks.
#2 The 6.0 owner should not be reluctant to bring their truck into the dealer and let them fix it- JMO
I had my truck at the Ford dealership for the same type of problem about 3 weeks ago. It had two problems causing it. A bad EBP sensor and the VGT solenoid was sticking. They replaced both and truck runs fine now.
This is the latest Ford Service Bulletin regarding the P0299:
2003-05 Various Running Problems, Check Engine Light; New EBP Sensor:
Trucks built before 1-17-05 that exhibit buck/jerk, hesitation, lack of power, stalling, stumble, black smoke, surging, rolling idle, changes in engine sound at idle or when driving at a steady speed, or with the trouble codes P2263 or P0299, may have an exhaust backpressure sensor signal that is incorrect or erratic. A revised EBP sensor is available if this is found to be the case. Part number 4C3Z-9J460-A. Broadcast Message 3815.
Normal EBP signal reading should reflect atmospheric pressure with the key on/ engine off. Typically, this is 14.7 PSI/0.88-0.9 volts at sea level, decreasing one PSI/0.10 volt for every 2000 feet of elevation. It should be within 0.5 PSI of BARO and MAP sensor pressure signals.
Hope this helps
