Fuel Pump Problem?
Old May 30, 2000 | 06:42 PM
samisage's Avatar
samisage
Fuel Pump Problem?
All,
I've got a 1985 F150 I-6 with some fuel delivery problems. There's plenty of gas in the tank and the engine will run with some gas poured in the carb but won't stay running.
I think the problem is the fuel pump. I looked down the carb while actuating the throttle and didn't see/smell any gas. I pulled the hose off the fuel pump inlet and found no evidence of gas (I expected a little to dribble out).
I also had a helper crank the engine while I stuck my finger over the inlet and found no evidence of suction. Is this a realistic test?
Is there any possibility that a "diptube" of sorts has fallen off the fuel gauge sender unit preventing fuel from getting up the fuel line?
Any thoughts would be appreciated.
Thanks,
Scott
Old May 30, 2000 | 07:15 PM
Bob_VT's Avatar
Bob_VT
Fuel Pump Problem?
Take the fuel line off the carb and stick it into a large soda bottle (20 oz) and crank the engine starter for about 10-15 seconds. The bottle should be half full or better. If not it's fuel pump replacement time.
Old May 31, 2000 | 07:37 AM
jmerritt's Avatar
jmerritt
Fuel Pump Problem?
