thanx to all
Old May 30, 2000 | 07:12 AM
texacejr's Avatar
texacejr
thanx to all
Got me a 1990 F-150 ext. cab I-6 last year. Never owned a Ford truck before this. Wanted to extend my thanx to all the knowledgable posters for their info. Now my truck runs like a top! Used several ideas from this forum. Cut old exhaust (rusted out) behind cat and ran out the side (not too loud either). BIG IMPROVEMENT. Also sidegapped plugs and gained power & mileage (18 hwy vs 15). All the extra power cost me about $25. Next step is to go to a 3.55 rearend limited slip if possible to find CHEAP (found the gear ratio calculator on another post). May install a B&M towing shift kit with deeper tranny pan and Crown Vic aluminum rearend housing this summer. I already have a tranny cooler from a 3/4 ton I got at the junkyard for $15. I'd like ta install a 240 head and an RV cam when I can (a family of 5 ain't cheap anymore). Just by being a faithful reader of this forum my truck runs better and I did it on a tight budget. Who says ya have to spend big bucks ta go fast. Thanx again & keep on posting those low budget tips. It's all some of us can afford
Old May 31, 2000 | 07:15 AM
Eddie's Avatar
Eddie
thanx to all
So you want a smokin' deal on a 3.55 R&P set, eh?
Just walk this way...
Mint condition OEM 3.55-to-1 set from my 1-owner '91, since regeared to 4.10.
Eddie (selt@flash.net)
Old May 31, 2000 | 01:32 PM
82F100SWB's Avatar
82F100SWB
thanx to all
I don't know if the computer will handle a 240 head, the compression ratio is 8.4:1 on a stock 300, and mine has ~10.25:1 now, if the computer will handle it, don't plan using regular gas hauling stuff again. Running mine off at the manifold(single exit) it sounds a little like a dragster, the sound of each explosion is distinct, instead of the normal dull I-6 sound, I can only imagine what it'll sound like with a split manifold on it. I have to get me one.
Evan MacDonald.
82 F100 FlareSide
84 300-6, 66 240 head
83 NP435(6.69 low)
Blue
Old May 31, 2000 | 09:26 PM
PAUL_2's Avatar
PAUL_2
thanx to all
