Need some help please, pretty seriouse
Old May 3, 2005 | 07:53 PM
iceman06's Avatar
iceman06
Today I was listening to my truck run while th hood was up and I have a lifter tapping on the passenger side. In order to get to the lifter I have to take off the valve cover and in order to get to the valve cover I have to take off the....I guess its called the upper manifold. Its the silver thingy that sits on top of the motor and it says 5.0 EFI. Well this thing, what ever its called is giving me problems. I have diconnected all the hoses in the front, which if I can remember is just the radiator hoses. I can't remember I am not looking at it right now. So the silver thing is lose and it twist back and forth. It almost acts like it has a bolt left in it somewhere but the only place would be up under it and that wouldn't make any sense because I don't know if I could get to it. I know that the ones I took out where two in the front, two on the sides and two in the rear. This is on a 1989 Ford f150 4X4. Thanks.
Old May 3, 2005 | 08:09 PM
xltlariat87's Avatar
xltlariat87
there is a bolt in the middle of the upper intake plenum, i believe it is a torx head bolt. can't remember what size t45 maybe.
Old May 3, 2005 | 08:56 PM
iceman06's Avatar
iceman06
is it on top or underneath everything? If its underneat, how in the heck do I get to it? thanks.
Old May 4, 2005 | 09:46 AM
iceman06's Avatar
iceman06
WELL, this is kinda of a seriouse situation here. I am trying to get this done pretty quick while I can.
Old May 4, 2005 | 09:59 AM
CobraXP's Avatar
CobraXP
There are bolts under the '5.0 EFI' plate that hold the upper intake to the lower intake manifold. Use torx head or screw driver (whichever the bolts are) and take that plate off. You should find two bolts under there, two bolts on the front, and two bolts on the back against the firewall.
Old May 4, 2005 | 02:25 PM
iceman06's Avatar
iceman06
well I finally got all this crap off and I have run into another problem. I found the lifter that is loose. Its the only one thats loose. When I tighten the bolt, its still loose. None of the other are like this. Its not REALLY lose, I mean I have to put some umpth into it to get it to jiggle around but none of the others do this. Could I have a warped lifter? Reply soon, thanks.
Old May 4, 2005 | 06:48 PM
iceman06's Avatar
iceman06
nevermind, everything is finished.
Old May 5, 2005 | 12:38 AM
munrow's Avatar
munrow
What did you find/fix/change...
Munrow
Old May 5, 2005 | 10:18 AM
Kemicalburns's Avatar
Kemicalburns
you replaced all the lifters right, not just 1.
Old May 5, 2005 | 07:57 PM
iceman06's Avatar
iceman06
i just tightened the bad one up.
