351w desperate for help
Old May 3, 2005 | 07:01 PM
hartattack's Avatar
hartattack
i have a 86 ford f250 351w 4 bbrl that needs help and i cant keep paying garage to guess and not work. the truck had but sitting all winter, started up but was running rough. i had a tune up done but it didnt change anything as truck was runing rough and backfiring still,. the timing was fine. the garage put in some antibackfire valves in the exhaust with no change, sputtering and no power, still backfires. they put in a a new alternator to provide power to the auto choke as they said it was dumping fuel down the carb and blowing out hte exhaust. here is the jest of it. the truck starts good, has an ok idle but as soon as you put in gear it stalls. when you finally get it moving with double pedaling it, it runs rough for a few minutes, as it gets hotter in sputters more and more and backfire reappers, gets louder and louder and eventually craps out. the plugs get fouled after 5 mins, when plugs replaced the truck has more horsepower and runs better but the process starts all over again. please help, i've poured tons of cash into to beast and seems like no one knows anything around here.
joel
Old May 3, 2005 | 08:58 PM
70T351W's Avatar
70T351W
I would almost bet after a period of sitting you have carbon deposits in your fuel system ( injectors or the carburetor needle & seat) that have hardened and is causing fuel to poor into your intake. It happened to my 351w, it sat for a year then one day I went to start it. It started fine and ran good at first but then it would flood out. The needle was not seating correctly due to build-up and sediment from the fuel. I put a carb. kit in it and that took care of that. Another thing you said about your plugs........if they are fouling out I promise you are getting to much fuel. when installing your carb kit be sure and recalibrate your floats to the carb kit specs. Tony
Old May 4, 2005 | 09:49 AM
Kemicalburns's Avatar
Kemicalburns
have you checked for vacum leaks possibly the carb isnt hooked up properly. what kinda carb is it. maybe your coil is bad not giving enough spark to the plugs. What is the timing set at. should be about 8-10*
Old May 4, 2005 | 09:59 AM
Momudder720's Avatar
Momudder720
Definite carb issue. Change that sucker out and I can almost assure you that your problems will go away.
'But why didn't the shop do that?'
Because they wanted to hit you with the BIG bill first, then charge you a measly $200 bucks for a $20 carb kit.
Old May 5, 2005 | 01:04 AM
munrow's Avatar
munrow
Sounds like the shop you went to was screwing you. WTF are "anti-backfire exhaust valves"?
Old May 5, 2005 | 07:25 AM
hartattack's Avatar
hartattack
is a carb fit a rebuild kit? thye said the timing was fine, i jsut dont understand why when you replace the plugs it runs great for about 5 mins them the plug turn to crap again, sputters and starts backfiring all over again
Old May 5, 2005 | 07:56 AM
Kruse's Avatar
Kruse
That carb is putting so much fuel down the intake manifold that the plugs are fouling from too much fuel. When you put some new plugs in, they work until they also get fuel fouled. While this is happening, your truck is belching out a lot of BLACK smoke, isn't it? As some other posters said, get that carb rebuilt.
You also will want a new fuel filter on your truck. The tank obviously picked up some sediment while it sat. The only other possible problem you have is bad fuel from sitting too long.
And get a new mechanic while you are at it.
Old May 5, 2005 | 08:03 PM
70T351W's Avatar
70T351W
for what it is worth i think this dilbert mechanic owes you ............or you owe him
