Distributor cap removal HELP???!
Old May 3, 2005 | 07:23 PM
oldRedTruck's Avatar
oldRedTruck
Question Distributor cap removal HELP???!
OK, I've done frame offs on Jeeps, swapped trannies, etc but for the life of me
short of taking a lot of stuff off, I can't figure out how to get the cap off!!!
Please help me out, it is in a very small tight area as you all know..
1987 2.9 L V6 Auto & AC
Thank you very much
Old May 3, 2005 | 08:27 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Just did mine tonight.You need a 7mm open edd wrench and a lot of patience.If the AC line is in the way there is a small bolt in the bacl side if the intake to get it lose to move it up a little.the bolt will be hard to get back in so dont remove it unless you have to.To remove the cap you have to take the spark plug wires off the cap.Just be patience and go slow. JMO
Old May 3, 2005 | 08:50 PM
oldRedTruck
Thumbs up
THANK YOU!! 8mm is the smallest I have, tried needle vise, pliers, phillips screw driver, etc...
2 posts, from what I saw, were eroding & had rust also..
darn thing is probably the original, the plugs were (and were quite worn!!)
Old May 5, 2005 | 02:23 AM
oldRedTruck
Got it! Thanks again. Wow, I've never seen a rotor look so bad!
Should be a fun commute in to work tomorrow with that changed too.
No more rough idle either
kjgibson2
117
Oct 29, 2017 10:22 PM
ezambrano3
Oct 7, 2015 01:40 PM
69issofine
Dec 10, 2014 12:59 PM
rdenis
6.7L Power Stroke Diesel
15
Oct 8, 2014 12:06 PM
jbirklid
22
Apr 2, 2007 12:57 PM
