302 heads
Old May 1, 2005 | 07:55 PM
fairlanehotrod67's Avatar
fairlanehotrod67
302 heads
I have got a set of 302 heads i have been running on a 351W. I drilled out the head bolt holes so they would fit. i am gonna double check but i think they are D5OE heads. Can someone tell me what valve are in these heads and the cc of the runners. I use them for drag racing is there a better stock head out there.
thanks donnie
Old May 1, 2005 | 08:26 PM
Hawkeye77's Avatar
Hawkeye77
D5OE - 1975 Fairlane/Torino
69cc chamber
1.78" intake
1.45 exhaust
1.94" X 1.04" intake port
1.24" X 1.00" exhaust port
I can't help with a head recommendation; it is just one part of many in the system.
Old May 1, 2005 | 09:46 PM
Bill Hanson's Avatar
Bill Hanson
69-70 351 windsor are good. They have larger ports, bigger valves 1.85/1.57, and smaller combustion chambers 60 cc. (you don't have to drill out the bolt holes) Even the early 289/302 heads are better than what you haveas far as cc's go. They can also be fitted with 1.92/1.60 valves. Bill.
Old May 2, 2005 | 08:22 PM
fairlanehotrod67
thanks for the info do know what the intake cc's are on both heads
thanks again donnie
Old May 2, 2005 | 08:45 PM
Bill Hanson
Donnie, I can't tell you the either the intake or exhaust cc's. I do know combustion chamber cc's from spec's. I also know 1.94/1.60 valves will fit from experiance. I also know the port sizes are larger on some more than others. I have also had some experience cc'ing some heads. How can I help? Bill.
Old May 3, 2005 | 09:21 PM
fairlanehotrod67
Bill, thanks for the info on the heads. I think i will set mine aside and go with aftermarket.
Thanks Donnie
Old May 4, 2005 | 05:57 AM
Bill Hanson
Donnie, Aftermarket heads are the way to go if you can afford it. However, they are getting some pretty impressive flow numbers from CNC preped 351 windsor heads at a fraction of the cost. Aftermarket aluminum heads offer lighter weight & higher compression ratios than cast iron heads. I guess if you can afford it go for it. Bill.
Old May 4, 2005 | 02:33 PM
fairlanehotrod67
302 heads
Bill, where can i get a set of preped 351 windsor heads. If they are alot cheaper i would rather go with them. My pockets are not really deep enough for aluminum. thanks Donnie
Old May 4, 2005 | 03:55 PM
Bill Hanson
Donnie, Check out Power Heads (www.powerheads.com). There is an excellent article on them in "Mustang&Fords" May 2005 issue. You also can pick up a set on E-Bay or flea market & have a shop build them to your needs. I am impressed with the results "power Heads" get & would probably go with them. ( Go with the porting, 1.94/1.60 valves, hardened seats, 3 angle valve job.) on the 351 heads and bolt on 40 horsepower. Bill.
Old May 5, 2005 | 10:27 AM
Kemicalburns's Avatar
Kemicalburns
AFR 185/205's are outstanding heads and produce some serious numbers right out of the box. i read in a mustang mag that they netted almost 70hp gain but need to find the article to double check. but you add the right cam and intake to that and you got your self a screamer
Old May 5, 2005 | 08:13 PM
Bill Hanson
You are right about the AFR's, they rank among the best. My friend had them on his 393 (351 stroker) mustang coupe and run 9.8's last summer. The 351 heads from power heads are $695.00. Bill.
