eec problems
Old May 3, 2005 | 10:54 AM
superf15071's Avatar
superf15071
eec problems
i was wandering if my eec is bad because when i try to get the troble codes the check engine light just stays lit continuosly ive also tried cheking for codes by using hooking up a voltmeter as shown in my haynes manual but i still cant get anything and i know im hooking up right cause i tried it on another truck and it will throw the codes so my question is if the eec is bad will it cause the problems im having with getting no codes
Old May 3, 2005 | 12:41 PM
superf15071
cmon on somebody yall r experts help me out
Old May 3, 2005 | 12:47 PM
Blurry94's Avatar
Blurry94
There is an easy procedure for pulling codes on fordfuelinjection.com
Old May 3, 2005 | 12:52 PM
95 F150's Avatar
95 F150
Just go out and buy a 30 dollar Actron code scanner, mine works like a charm and was well worth the money to me. On a side note EEC's rarely go bad.
Old May 3, 2005 | 01:09 PM
superf15071
i used the procedure on that site it just want do anything the eec is getting power i checked and the grounds r good i dont waht else to check
Old May 3, 2005 | 02:54 PM
EPNCSU2006's Avatar
EPNCSU2006
What year, engine and transmission? If it is a six cylinder with a manual transmission, you must hold the clutch pedal to the floor for the duration of the computer self test.
Old May 3, 2005 | 09:50 PM
superf15071
oh really ill try that tomorrow thanks
Old May 4, 2005 | 02:31 PM
superf15071
okay the truck is a 1987 f150 xlt lariet i tried to do the check with the clutch mashed in the whole time still didnt work could it be my computer is just messed up becuz when i went to get the truk they stuck another battery in it to crank it and then tried to put the dead battery back in and the cables touched could this be what fried my computer . ps i was just told about the whole battery cables touching today
Old May 4, 2005 | 09:36 PM
superf15071
bump plz help
Old May 4, 2005 | 09:45 PM
Popa Tim's Avatar
Popa Tim
If the computer wont go into diagnostic and you are very sure you are doing it right then its a good sign of a bad computer.
Old May 4, 2005 | 10:04 PM
superf15071
thanks im gonna try it again tommorow just to be sure but if not i can get a computer for like 30 bucks if the place has the right one. but im pretty sure im doing it right because ive tried using the faq on fordfuelinjection.com and my haynes manual and i couldnt get it to do anything plus something keeps killing the batteryso now i gotta charge it.
Old May 4, 2005 | 11:39 PM
EPNCSU2006's Avatar
EPNCSU2006
You are looking at the red "Engine" light (comes on when there's no oil pressure, i.e. engine off). There is no "Check engine" light to blink on an '87. You have to use the volt meter method to pull the codes unless you wire in the check engine light in the dash. I highly doubt that your computer is bad, and if it is, it is too soon to be condemning it. What engine and transmission do you have?
For volt meter method: connect jumper between STI and SIG RTN (ground), then connect a volt meter between the positive battery post and STO wire on the self test connector. Turn the key on and count the sweeps of the volt meter (analog volt meter).
Old May 5, 2005 | 02:00 AM
superf15071
ive tried that method and it still doesnt work. but i have an inline six and 4 speed with overdrive manual transmission
Old May 5, 2005 | 06:35 AM
EPNCSU2006's Avatar
EPNCSU2006
When jumpered correctly (and the computer is functioning correctly), the check engine light (volt meter) should show 12V when you hook it up, then drop to zero the instant you turn the key on. Did you try that method with the clutch pedal depressed? Are there any other things that the computer is doing (or not doing) that would suggest it has failed? It could be broken, but it seems like there is something else going on than a failed computer (although I wouldn't rule it out).
Old May 5, 2005 | 11:38 AM
superf15071
wel lets see none of the fuel pump circuitry is getting any power and yes ive tried that method with the clutch depressed. the haynes manual i have has a checklist to of points to check so u can fine the short in the fuel system and the first few steps pass fine then i get to the step that has sumthin to do with computer and it want work and the reason it gives for that wire not responding is (possible eec failure) so i dont if its messed up or not. but thanks for all ur help i really appreciate it alot
