1978 - 1996 Big Bronco
Steering box
Old May 2, 2005 | 07:41 PM
pup55's Avatar
pup55
Steering box
I have a 1993 Bronco which has sloppy steering. I had a front end alingment and was told of no problems with the front end. I just replaced the steering box with a rebuilt from ford. When I got the truck back it was a little better but not by much. The truck has 33" tires which at slow speeds wanders. At high speed the truck is much better. I have also replaced upper and lower ball joints. Could someone please tell me what else might be causing the problem?
Old May 2, 2005 | 07:44 PM
Streetgang's Avatar
Streetgang
I dont totally understand exactly whet you mean by "sloppy steering"......are you saying you have play in the steering wheel.....because there is a adjustment for that.....?????
Old May 2, 2005 | 07:48 PM
pup55's Avatar
pup55
The steering wheel has alot of play in it.
Old May 2, 2005 | 10:31 PM
Streetgang's Avatar
Streetgang
Ok......on the top of your steering gear box there is a sector shaft adjusting bolt....I think thats what they call it. You need to loosen the lock nut and then turn the screw/bolt to the right until you take most of the play out (out of the steering wheel that is.....NOT the adjusting bolt). DO NOT.....go to far with it......you will know that you have gone too far if after you make a turn the wheel dont want to come back to center on its own.
I would start with 1/2 a turn on the adjusting bolt.....lock it back down and drive it.....if that is not enough.....go another half turn, and try that.....and so on.....and so on. Let us know how you make out....... JUST REMEMBER.....you dont want it too tight/too far.
Old May 3, 2005 | 06:07 PM
pup55's Avatar
pup55
Thank you for your reply. I still have to adjust it even though it is a rebuilt steering box from ford?
Old May 3, 2005 | 08:13 PM
Streetgang's Avatar
Streetgang
Well......I would look at all other possibility's first.....check your rag joint (toward the bottom of the steering shaft), and any other place that there could be play in the shaft could be a u-joint on there. Anyhow if you can move the steering wheel back and forth more than a inch or so before the front wheels move there are only two or three places that could be worn. If the shaft feels/looks solid.....then yes, I would adjust the gear box.
Old May 3, 2005 | 08:50 PM
greystreak92's Avatar
greystreak92
I know you posted that the front end was given a clean bill of health but were the axle pivot and radius arm bushings checked along with rod ends. ALL of these items can contribute to a sloppy steering situation.
Old May 3, 2005 | 10:54 PM
aurgathor's Avatar
aurgathor
If the steering box was just replaced, check out everything else before adjusting it. And if you do adjust it, go in no bigger than 1/4 turn steps.
Old May 4, 2005 | 05:58 PM
pup55's Avatar
pup55
Thanks again for your reply. I will check the rest of the front end out and let you know what I find.
Old May 4, 2005 | 06:00 PM
pup55's Avatar
pup55
I will check the axle pivot and radius arm bushings. The tie rod ends were ok. Thanks for your help.
Old May 4, 2005 | 06:23 PM
Streetgang's Avatar
Streetgang
rad arm bushings will not cause left to right play in the steering wheel.
If when the truck is sitting still and running you can move the steering wheel more than a inch or two (I can look up the exact specs and procedure to get it with in them, but I am too lazy and they are very detailed) it needs to be corrected. You need to see where the "play" is coming from......there are not all that many places.....either the u-joint or rag joint (not sure what you have), steering gear box itself, steering gear box adjustment.....thats above the pitman arm.....below the pitman arm you have a few things that could do it, but these are very easily spotted.
Have someone turn the wheel while you go under the truck and see where the play is.........if I had to bet, I would say the sector shaft needs to be adjusted.
Its not the radius arm bushings.......
