Offroad & 4x4
Track Bar
Old May 2, 2005 | 07:35 PM
bonechief's Avatar
bonechief
Track Bar
Okay If was to build myself a custom track bar......I would attach it to the frame on one side and the axle on the other end.....I figure to make it with an adjustable Heim joint at one end and then solid to the frame...Any suggestions anyone.........................
Old May 2, 2005 | 08:50 PM
fishmanndotcom's Avatar
fishmanndotcom
yea, i went to a tractor supply place and bought a 3 point hitch adjuster that has 'heims' on both ends but it adjusts. cost me $15. hell i think i might still have it around here somewhere.
-cutts-
EDIT.... for reference, go here... and its the top red bar! http://tderen.tripod.com/images/proe_hitch_linkage.jpg
Old May 3, 2005 | 10:43 AM
Momudder720's Avatar
Momudder720
What you'll want (if you're building it yourself) is a LH heim on one end and a RH heim on the other. That'd make it adjustable. Those 3-pt parts are good to use on the cheap, but they loosen up pretty easily and aren't made of the best quality steel. They also don't quite fit real tight, so there's a little more slop.
Old May 5, 2005 | 12:24 AM
mark a.'s Avatar
mark a.
Look in my gallery.
