Distributor
Old May 2, 2005 | 07:27 PM
crack's Avatar
crack
Distributor
the distributors on both my 351M and 400 are siezed in their current location so you cant time them at all...is there a way to unstick it?
Old May 2, 2005 | 08:35 PM
TxBrokenarrow's Avatar
TxBrokenarrow
soak it with penatrating oil for a couple of days...mine did the same thing and after 3 or 4 days it was begging to come out...you have to give the penitrating oil time to work...it will come loose...when you reinstall it coat it with anti freeze on the shaft where it contacts the block...
Old May 2, 2005 | 11:56 PM
beeboy's Avatar
beeboy
also, I still had to hammer on mine to get it out. There is a spot under the wide part of the dizzy where you can get a punch on it, and whack it with a hammer to try and get it to spin. You can also sometimes get a slide hammer on them and yank them that way.
Old May 3, 2005 | 12:17 AM
crack's Avatar
crack
I put some ATF on it a while ago and it hasnt loosened up to the point where I can move it by hand..but maybe some hammering could assist it
Old May 16, 2005 | 04:02 PM
7fords's Avatar
7fords
txbrokenarrow dont you mean anti seize?
Old May 16, 2005 | 06:09 PM
TxBrokenarrow
sorry..thats what i meant...another piece that will freeze up is the alternator bolt that bolts to the block...
Old May 16, 2005 | 06:31 PM
fordfury469's Avatar
fordfury469
when ever my dizzy freezes up i hit it hard with a hammer, then go buy a new one for 25 bucks.
Old May 16, 2005 | 06:36 PM
danlee's Avatar
danlee
I have used a small flat nail puller. You get it under the lip on the dist. and hit the puller with a hammer. If you can move the dist. just a little, then you can squirt PB Blaster into the crack. Then it should loosen up after a while.
Old May 17, 2005 | 12:16 AM
crack's Avatar
crack
what the blood is PB blaster, I asked some shops and they dont havea clue what im talking about, it it an american thing?
Old May 17, 2005 | 06:08 AM
danlee's Avatar
danlee
PB Blaster is a brand of penetrating oil, like WD40 etc.
Old May 18, 2005 | 09:19 AM
Bill_Beyer's Avatar
Bill_Beyer
I've used PB Blaster and it's OK, better than WD-40 but my all time favorite is Kroil from Kano labs. Stuff will unstick most anything, at least everything I've tried it on. Google it and you'll get to their website where you can order it online. Unfortunately I only discovered it after I ended up using an air chisel on the dist in my 400.
Unsticking the dist in a 351M/400 kinda reminds me of what Bob Uecker said when he was asked about the best way to catch a knuckle ball, "Wait until it stops rolling and then go pick it up." With the 351M/400 dist you can try to get it unstuck without busting it or just go buy a new/rebuilt one and not worry about tearing up the old one.
Old May 18, 2005 | 07:23 PM
crack's Avatar
crack
wel lto put a new one in it, you still needto get it unstuck to get out.
Old May 18, 2005 | 07:26 PM
danlee's Avatar
danlee
If you have a new one to put in, then hit it with a hammer.
If that doesn't work, get a bigger hammer.
Old May 28, 2005 | 08:14 PM
crawlfish's Avatar
crawlfish
Stubborn Distributor
Mine seemed to be welded in place. Nothing worked, no prying, tapping, twisting or soaking in penetrants for a week worked...
The only way I was able to get it out was to remove oil pan and pump and tap the oil pump drive rod . Came right out.
When replacing definetely go with the suggestion for anti-seize.
hharris8
Aug 27, 2016 09:11 PM
B Dobz
28
Jun 25, 2012 05:46 PM
BubbaDrake
Jan 18, 2007 11:06 PM
nevereverquit
Dec 29, 2003 06:59 PM
