Disc Brake Question......
Old 05-02-2005, 06:43 PM
89F150Custom's Avatar
89F150Custom
89F150Custom is offline
1989 F150 front disc brakes - I took apart the front brakes, and am changing the calipers. When I took the outboard brake pad out, there were no anti-rattle clips on it. Before I put everything back together, my question is - are there supposed to be anti-rattle clips on the outboard pads, or only on the inside ones?
Old 05-02-2005, 09:01 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
Unless they changed things between the '89 & '90 models, my clips are only on the pads that are against the pistons. I would advise bending the tabs that fit into the calipers on the outboard pads to keep they tightly in place. But maybe that's were I earned my nickname?!? ...Terry, '90 F150
Old 05-03-2005, 06:15 PM
89F150Custom
Thanks for the help, I just wanted to double-check before putting it all back together.
Old 05-14-2005, 10:34 AM
89F150Custom
Is there an easy way to bend these tabs? I tried to bend them as best I could (which wasn't very much), but the driver's side pad is rattling around in the caliper.
eigenvector
1983 - 2012 Ranger & B-Series
12-27-2015 02:31 PM
emgee
09-07-2014 08:38 PM
ArdWrknTrk
40
07-08-2014 09:11 AM
justplumducky
06-09-2014 10:34 AM
jbondi
10-06-2006 06:00 PM
Quick Reply: Disc Brake Question......
