Starting to get frustrated...
Old May 2, 2005 | 03:28 PM
silly34's Avatar
silly34
Damn this A4WD. It feels like the front wheels just keep binding. Especially when there is a load in the vehicle or even when just going up a hill. Really really sucks.
B.
Old May 2, 2005 | 06:04 PM
PaulC's Avatar
PaulC
Assuming no problems with the shift motor, I would look at the age of the transfer case fluid as a potential culprit. I had a similiar, but less severe problem in my '99. Ford dealer checked out the (non-limited slip) differential, took apart the front axle and diff, found nothing. I suggested that it felt like the transfer case had 4HI partially engaged. Skeptical service manager contacted the company, company rep said flush the transfer case a few times with new fluid, problem went away.
Old May 2, 2005 | 06:36 PM
Luzer27's Avatar
Luzer27
Provided you are not loosing traction then the system is passive. So it might be engaged for the wrong reasons. Also if nothing else helps your situation you could always pull the fuse or add a switch as others have done.
Old May 2, 2005 | 06:53 PM
silly34's Avatar
silly34
I've pulled the fuse, doesn't help. I will look at getting the fluid changed but if that doesn't do it what else could cause it??
B.
Old May 2, 2005 | 08:44 PM
FTE Herman's Avatar
FTE Herman
Changed any tires lately? If the difference in the diameters of the tires varies by too much (I don't know what too much is) the A4WD can engage under otherwise normal driving conditions.
Old May 3, 2005 | 07:10 AM
2Fords1Jeep's Avatar
2Fords1Jeep
Not sure about Ford transfer cases, but Jeeps have a viscous coupler (VC). The VC is liquid filled and when they go south the vehicle is in 4wd all the time. Sometimes by changing the fluid in the differentials and the transfer case to synthetic fluid solves the problems by keeping fluid temperatures down. As someone else suggested, it make take a couple of fluid changes.
Personally speaking it didn't work for my Jeep. I had to buy a new VC.
richdawg
May 5, 2013 10:41 PM
CircleV
Mar 25, 2013 03:26 AM
Tjdb2000
Jun 28, 2007 07:25 AM
Jerrod
28
Jun 1, 2004 02:00 AM
Tylus
Mar 12, 2004 01:04 PM
