Gage light replacement ?
Old May 1, 2005 | 10:35 PM
oldcoupe42's Avatar
oldcoupe42
The lights went out on my oil pressure and water temp gauge in my 95 F150. What's the SOP to replace them ? (I hope I don't need to reach up behind the dash)
Thanks, Chet
Old May 2, 2005 | 08:05 PM
95X15's Avatar
95X15
Take the black plastic surround offpulls out of clips in dash - remove headlight **** by reachig behind **** with a bent tool like a cotter pin bent 180 degrees and release the spring clip inside the back of the **** (lights on - battery disconnected). Once you get that far remove dash display screws and pull out bulbs turn 1/4 turn into hole in back of dash. Plan on replacing them all unless you want to do this often. I think this is about right I haven't done this in a while - if anyone sees any thing I missed please jump in.
Thanks.
Old May 2, 2005 | 11:04 PM
MemOrex's Avatar
MemOrex
Read this article. It shows how everything is removed.
https://www.ford-trucks.com/article/...Or_Bronco.html
