Tuner question
http://www.motorhaven.com/home.php
They are having a sale now
A lot of tuner discussion, here, has often left us falling into the bowels of hate and discontent. Actually indirectly cost us a couple of really good and well informed members.
For my $.02 worth...I have the Predator but I am sure I would have been equally as happy with the Superchips.
In regards to coolant puke. We have seen both stock and tuner 6.0s evacuate coolant.
In addition, again IMO, if you are looking for MPG gain....stay out of the tuner business. It's just to hard to drive conservatively or with an real sense of maturity with one of these things.
The diablosport will not make power past 3600.
With regards to blowing coolant, I know that many trucks have done it with different things going on. But from reading on here (which I do a lot) it seems to me that truck towing heave loads (10,000lbs +) and trucks using the predator seem to be the majority. So when I hear that the two tuners discussed in this thread make power differently, I wonder if one of them lens itself to blowing coolant.
Both tuners have their own following...you gotta get the one you like best.
I would suggest you try both.
With that said, I lost coolant under normal driving conditions and no towing prior to the addition of my Predator. After programming, I only lost coolant during light tow conditions, still in the 65 H.P. mode. BTW: I haven't towed over 6,000 #. After programming, I never lost coolant when not towing.
So in my limited case. The programmer actually minimized the opportunity for coolant losses.
BTW Pickupman2004: I did not mean to even imply that you were trying to start a war. It was merely a cautionary advisory.
I can tell you the diablo does not run more boost than the superchips, but boost is not a good indication to overall cylinder pressure anyway.
The diablo adds fueling (so does the sc), and runs a different injector timing curve than the sc unit.
Superchips changes fuel, injector timing and actually runs more boost (more boost keeps egt's low).
Diablo raises cylinder pressure through fuel and a different timing curve than superchips. Boost levels are closer to stock with the Diablo tuner, but this does not mean it runs less cylinder pressure than SC. (clarification: I am not making the assumption that it runs more cylinder pressure than SC, either). This post must remain neutral...
The point I'm making here:
Cylinder pressure can be raised by fueling, injector timing, injector pulse width, removal (or lessening) of torque reduction, boost, propane, nitrous, etc...
Raising (or lowering in some cases) of any of the above and a combination of any will raise cylinder pressure.
To be fair, I WILL NOT state anything as to my opinion of which is better, and which of the explained attributes are good or bad.
I just wanted to post a few facts to make sure there was no confusion.
Both the Diablo and Superchips tuners will raise cylinder pressure, and there is a range where it is safe to raise cylinder pressure.
Every manufacturer has their own method of testing to determine what is safe, and both products have been shown to run just fine in MANY vehicles.
In a turbodiesel, it is quite possible to have more boost but less cylinder pressure. The opposite is also possible.
As a general rule, this holds true:
-More boost lowers EGT
-More fuel (be it in pulse width or ICP) raises EGT
-More injector timing raises EGT
I can appreciate how difficult it can be at times, for someone in your position, to offer up a very measured yet informative response to comparative tuner questions like this.
Thanks for keeping the playing field as level as possible.
