Air/fuel Mixture Screw
Old Apr 30, 2005 | 10:34 PM
BJScott1986's Avatar
BJScott1986
Question Air/fuel Mixture Screw
I HAVE A 1BBL CARTER YFA FEEDBACK CARB. I spent the time today to rebuild it, and the instructions stated that the air/fuel mixture screw was set from the factory and not to change it. I bought the truck used, and the carb had been replaced. I dont believe the screw is set right, does anyone know what the correct setting is?
thanks
Old Apr 30, 2005 | 11:46 PM
LxMan1's Avatar
LxMan1
Screw it in until the idle speed starts to drop. Then back it out until you get the highest idle/vacuum, then turn it back in about 1/2 turn. This should be done with the engine at normal operating temp.
1984Ford300six
19
Aug 29, 2014 12:12 PM
EvoDawg
Nov 15, 2009 03:58 PM
tdw17979
Nov 3, 2009 07:20 AM
kenworth20
Nov 24, 2006 02:52 AM
youngguy
Jan 15, 2004 10:38 PM
