Bronco II Ford Bronco II
a4ld torque converter
Old Apr 30, 2005 | 05:59 PM
peck87's Avatar
peck87
how can i tell if my torque converter has gone bad? i had to remove the tranny because of a blown front seal and cannot get my converter to seat all the way.also it gave the signs of a blown seal but it does not look bad. any help is much appreciated!! THANKS, PECK
Old Apr 30, 2005 | 09:41 PM
redlightning's Avatar
redlightning
I had an 88 with a bad converter.Mine would not move.I took it off and looked inside and I could see where the splines inside the converter where rounded off.I replaced the converter and it was fine.I don,t know what caused it to round off, I got it not moving.
Old May 1, 2005 | 06:05 PM
Help I M Stuck's Avatar
Help I M Stuck
when you put the torque convertor back on..keep turning and pushing on it will CLICKS 3 TIMES..then it is in position. Also..if the front main pump seal was leaking or appeared to be leaking..it is VERY POSSIBLE the covertor is bad also. I had my trans in and out 3 times replacing the front main pump seal just to find out it was the convertor that was doing the leaking.
Old May 1, 2005 | 07:57 PM
maples01's Avatar
maples01
If it's leaking out the housing when shut down, faulty torque converter, cracked weld. If you have it out, take it to a shop and have it looked at, they can repair it.
I don't see it going bad and not going it, sometimes it takes a lot of turns to get it to finally fall into place, don't push too hard while turning either, that will also make it difficult.
Old May 2, 2005 | 07:58 PM
peck87's Avatar
peck87
okay, i finally got brave enough (or dumb enough) to unbolt the bellhousing from the tranny.then i tried to fit it back to the converter. it fell right in place.i have no idea why it worked but hopefully when i replace the front seal it will work right again. the converter is fine.so hopefully i will have no more problems.any more input is greatly appreciated!!!! thanks for all of the help so far!!!!
Old May 2, 2005 | 08:08 PM
maples01's Avatar
maples01
Dude you got so lucky, I hate the torque converter stud bolt up because lining up is so difficult.
Marioj87
2004 - 2008 F150
Jan 12, 2016 08:50 AM
Jamie Peck
May 28, 2015 12:54 AM
browntown3
Jan 30, 2015 01:38 PM
browntown3
Modular V8 (4.6L, 5.4L)
Jan 29, 2015 03:18 PM
Diesel Junky
Mar 12, 2013 09:43 PM
