Hello,
just got a 70' 302 Mustang. I am trying to figure out what the engine block code means. I just want to figure out RPM, heat range, the usual data. Any body have any ideas?
Code is c8am-6015-b and the bottom code is 26g9. all i seem to get on the internet is for a F-150 P/U.
Thanx,
Mike
Hey Mike if you havent already got your information call the ford dealer and ask for parts. Tell them what you are needing to know and they should have the answer, if they are nice.Tony
double check the codes you gave us!I can't find anything close to it.C8 is 68,A is galaxy carline,the m makes no sense it should be the letter e =engine!date code is july 26 1969!recheck the the cdes again,might half to clean a lil' more! hope this helps!
