390 engine code help
Old Aug 21, 2013 | 09:52 PM
Mullholland_F100's Avatar
Mullholland_F100
Hi, I just bought a 56 f100 with a 390 and c6 auto trans. I found my engine codes and am now not sure if I have a 390? Any help would be appreciated.
Code on intake manifold - C8AE then just below that 9425-F
Code on block on passenger side - C6ME-A
Code on block on drivers side next to oil filter - 7F20 - this one is a bit hard to read
Not sure what all the codes mean, but from what I can find it says 428 Police interceptor? I've read that it's hard to know for sure without measuring the stroke, but would these numbers be on a 390 at all? I also saw the drilled holes near the bottom of the block. Is this a mark of a 428?
Thanks
Old Aug 22, 2013 | 04:21 AM
big job's Avatar
big job
Codes have always been a hassle for me. As you know at one look they all look the same. Unfortunatlly you have to measure it. Maybe stick a rod down there and measure the stroke. The old story to pass off a 352 with 390 valve covers
who knows?? (I've seen that old trick before)
Old Aug 22, 2013 | 05:18 AM
F100FE's Avatar
F100FE
Is there a tag on the distributor? That's the one you are looking for, it gives you all the information.
Old Aug 22, 2013 | 11:10 AM
jim collins's Avatar
jim collins
Distributors along with valve covers get changed around, no proof that way . You have to measure the stroke though the spark plug hole or pull the heads to really know , bore is the same 360 / 390 . I believe the 428 is bigger bore , I had one but don't remember for sure .__
Old Aug 22, 2013 | 12:46 PM
arctic y block's Avatar
arctic y block
Let's see the "Drilled Holes Near The Bottom Of The Block"
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Aug 22, 2013 | 01:15 PM
Mullholland_F100
Thanks for the replies. I also posted this in the engine forum and got the code decoded, but as most of you know it's still a lot of options. I just have to measure the stroke. I have pictures of the codes, but not the holes I noticed. I will try to crawl back under the truck today to see if I can snap a pic of what I saw.
These old engines is all new to me so it will be a learning expierence. I just kinda want to know what I have so I know where I'm starting from. I ordered a bunch of parts from summit assuming it was a 390 4V. I ordered a new roller cam, aluminum rocker assembly, ededbrock rpm intake, edelbrock carb, new MSD dist and coil and gaskets and bolts all around, Looking at some sanderson headers that will fit on the 56.
I'm just hoping that if it is a 390 2V it's not a waste to put all the new parts on it if it's not the 4V. And I was kinda not wanting to pull off the heads if I did not have too. They seem to be leak free so I was hoping to just pull the parts I have too and change a few gaskets (manifold, valve covers, oil pan, possibly rear main if leaking from there).
Anyone here ever do the upgrades I'm doing on a 2V or 4V? If so how was it? What kind of power did you get?
Thanks
Old Aug 22, 2013 | 01:54 PM
arctic y block
Just a heads up.
The FE intake is a bear to get to seal around the back.
It is one place that ya have to use RTV.
Old Aug 22, 2013 | 01:56 PM
lgfuller's Avatar
lgfuller
really only difference between the 2v and 4v is wether it has a 2 bbl carb or a factory 4bbl. i think the 4v has slightly bigger valves. its not like there were 4 valves per cylinder like on some of the newer engines. best thing for them is carb, cam intake and headers. and power numbers are possible in the 550 range when theyre built right....ive seen more out of FE head engines, but not too often......
Booflar
Jul 4, 2019 04:33 AM
Mullholland_F100
16
Aug 23, 2013 03:57 AM
ryan f150 4x4
May 28, 2013 02:01 PM
rpharesjr
Aug 11, 2012 11:19 AM
classic4x4
Sep 21, 2007 04:54 PM
