Sponsored by: Real Truck
Door Rattles
Old Apr 28, 2005 | 10:00 AM
DickyBoy's Avatar
DickyBoy
Door Rattles
DOOR RATTLES ANYONE... Please help save me some time and trouble..I've got a 2001 F350 Super Duty,with 127,000..and I've got this rattle that sounds like Its comming from the drivers side doors. Any suggestions,Thanks,Dick
Old Apr 28, 2005 | 10:32 AM
bedwards's Avatar
bedwards
Mine was the rear door latch on a CC. Greased with lithium grease shut it up.
BE
Old Apr 28, 2005 | 10:35 AM
FordRuss's Avatar
FordRuss
Does the rattle go mostly away with the window down & your arm on it?? I had a loose window track that was driving me nuts.. I have a hex bolt about 6" below my door latch that was loose. It looked tight until I put a wrench to it.. If that's the case, tighten with the window down & then carefully raise it.. You may have to raise/lower the window & adjust a few times until it doesn't bind & rattle..
Good Luck,
Russ
Old Apr 28, 2005 | 12:59 PM
hc130flyboy's Avatar
hc130flyboy
mine will rattle above 55 with the windows up or down. cant trace it for the life of me. 00 CC
Old Apr 29, 2005 | 01:53 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
mine rattles when I have the truck twisted going in and out of driveways, etc. and the body is flexing. 22,000 miles, started at about 2,000. adjusted the latches/strikers,
went away, but came back a few thousand miles later.... drives me nuts too
Tim
