i have an 86 f250 with a 460. its got the shakes and rattles at 1500 rpm and up. i set the base timing at around 8-9. when i bring it up to 1500 rpm or higher the advance timing goes up around 30 degrees. when i removed the vac advance hose from the dizzy the shakes and rattles went away. what would cause the advance timing to go so high and what is causing the shakes and rattles? its really getting on my nerves. please help. thanks in advance.
The timing is advancing so far because you are causing a high manifold vacuum and the ported vacuum fitting is pulling the timing around. Does it do this shaking thing when driving down the road? Probably not, as the vacuum would be lower because the throttle plates are open farther. I wouldn't worry about it as long as it only does it in neutral. BTW you should be doing it anyway, it's hard on the engine.
yes it does the shaking and rattling when driving. could i plug the the ports off and run with no advance timing or would this hurt the engine. it has 160,000 on it.
You could disconnect the ported vacuum but it will hurt your gas milage a whole lot. Did this just start happening all at once or was it a long time is getting worse? I suspect you need to check your total mechanical advance and also how strong your spark is at the plugs. I think you are having and ignition system break down. When you back off on the timing you make the ignition not work so hard. Plug wire could cause this also.
The first thing that came to mind as I was reading this is: The Harmonic Balancer have the timing marks rotated? If memory serves me they advance. Food for thought.
True and thats why you need to check TDC with the compression against your finger, then find TDC with a dowel through plug hole. That will let you know if it is off.
