Trick to regain compression?
Old Apr 27, 2005 | 07:25 PM
DuraSparkMike's Avatar
DuraSparkMike
Exclamation Trick to regain compression?
Has any of you guys ever filled the crankcade with ATF and run the motor for a few minutes to clean stuck rings and valves.? Apparently it makes the rings snap back into their "good compression" position. Don't know what type of ATF though (Mercon/Dexcron, TypeF?)
Please let mr know.
Old Apr 28, 2005 | 09:58 PM
maples01's Avatar
maples01
http://www.auto-rx.com/
I plan to order it soon myself, they have $4 off currently, making it about $20 a bottle.
Old May 5, 2005 | 01:31 AM
munrow's Avatar
munrow
Haven't heard about using ATF to "fix rings". Have heard about using it to clean oil passages, oil pump screen, etc.
Old May 5, 2005 | 07:25 PM
trike1946's Avatar
trike1946
It is also supposed to help when added to diesel fuel. Never tried it but I am thinking I might.
You might try asking in the general automotive forum. Or maybe in the transmission forum. The trans gurus probably know what type to use. Post back and let us know how it works. Good luck with it.
dustydogg31
May 24, 2016 06:29 PM
rblaine9000
6.4L Power Stroke Diesel
Nov 23, 2013 03:38 PM
99F-350CrewCab
Jul 7, 2011 10:11 AM
Tyler Burdett
24
May 12, 2009 09:50 PM
Aerocell4x4
Oct 27, 2008 09:22 PM
