Traklok or Auburn
Old Jul 27, 2000 | 12:04 PM
meck's Avatar
meck
Traklok or Auburn
I need help choosing a limited-slip rearend. Given what I want it for, I had narrowed my choice down to either the Auburn HiPerformance or the Spicer Traklok (it's for a F250 with a 10.25" Ford differential). I thought they would be roughly comparable for the primarily highway use of my truck. Now, I hear that the torque transfer on the Auburn is twice that of the Traklok. Is this true? Since I will occasionally be pulling a heavy boat up a steep boat ramp, this info. concerns me. What can anyone tell me about the actual performance differences between the two?
What about longevity?
Thanks,
Old Jul 27, 2000 | 06:12 PM
StrangeRanger's Avatar
StrangeRanger
Traklok or Auburn
The Spicer should be much longer-lived than the Auburn. It will also have a lower bias. The Auburn is a very good performance unit, great for hard launches or putting power down coming out of a corner, not what you're likely to need in a truck. The Auburn is not rebuildable, it's strictly a use it up and throw it away item. The spicer is rebuildable but you're unlikely to ever wear it out.
For a Mustang, I'd go with the Auburn, for a truck, I'd go with the Spicer.
Old Aug 2, 2000 | 07:27 PM
Phillip Guidry's Avatar
Phillip Guidry
Traklok or Auburn
You may consider an " Eaton Posi" as well. Totally rebuildable with clutch packs on both sides. And, with a name like Eaton, how can you go wrong. I think you can just type eatonposi and get to there web site.
Phil
Old Aug 3, 2000 | 10:03 AM
whaynes's Avatar
whaynes
Traklok or Auburn
I went with the Detroit TrueTrac L/S. Excellent road manners, they have a good positive action when wheels are slipping and they don't have clutch packs or need special lubricants. As for the Auburn, I was told that the cone was replaceable. I could be wrong though. Either way, of the the L/S's that you mention, they all should work pretty good.
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in, 4.10's
Detroit TrueTrac's
Old Aug 3, 2000 | 11:04 AM
mag's Avatar
mag
Traklok or Auburn
Pipelinewelder20
Sep 2, 2014 03:58 AM
Sir Nick
Dec 23, 2012 11:02 AM
mikefender
Dec 17, 2010 01:29 PM
ghunt
Oct 22, 2009 10:52 AM
jmkelly
Jan 11, 2009 10:03 AM
