weiand 8010 install
Old Apr 27, 2005 | 11:50 AM
TxBrokenarrow's Avatar
TxBrokenarrow
weiand 8010 install
i'm going to be installing a weiand 8010 with a holley 80457s (4160)...i'm trying to have it look as clean as possible...or more like without a bunch of hoses a wires going every where...i think i should hook up the pcv hose to the carb but where do i hookup the brake booster vacume hose???would a carb spacer with a vacume fitting work???thanks
Old Apr 27, 2005 | 11:57 AM
kc5hwb's Avatar
kc5hwb
On my edelbrock, the vacuum booster went to a vacuum port on the intake. It should have ports on it, or at lease holes for the ports, so you can put a plug in with a port for a vacuum line.
Old Apr 27, 2005 | 02:16 PM
tastyklair's Avatar
tastyklair
The spacer would work. Most manifolds have a provision for a fitting. If you go the spacer route make sure of your hood clearance and check out some of the differences. Some spacers can also help with performance gains. Stay away from the open type, you should look for one with the 4 separate holes.
Old Apr 27, 2005 | 07:21 PM
danlee's Avatar
danlee
The Weiand 8010 has a plug at #4 cylinder. Remove that plug and install a fitting for your vacuum.
reebadoo
Jan 28, 2015 01:35 PM
79super460
Oct 19, 2012 12:39 AM
79f150monster
Mar 2, 2011 08:58 PM
lud04X
Jul 13, 2007 02:56 PM
cruz76
Mar 25, 2007 06:28 AM
