Offroad & 4x4
swamper p.s.i.
Old Apr 27, 2005 | 08:58 AM
mark a.'s Avatar
mark a.
swamper p.s.i.
I've settled on 25 in the front & 22 in the rear in my t.s.l. 42's. They seem to be wearing all the way across the tread there. Whats anybody else running ?
Old Apr 27, 2005 | 10:55 AM
ivanribic's Avatar
ivanribic
That's exactly what I'm running in my 44's now. Tread wear seems to be minimal! I suggest to anyone else looking to make a Swamper last longer that you leave them on the patio. It's amazing but almost 2 months now and I haven't seen any change in my tread.
Old Apr 27, 2005 | 11:22 AM
Saurian's Avatar
Saurian
Yeah, that'll work Ivan.
Better idea would be to get the biggest darn AT tire you can and an extra set of steelies for the drive to the event, that way your big soft-compound tires never see pavement except for when you're mallcrawling like Ivan.
Old Apr 27, 2005 | 12:25 PM
tellico racing's Avatar
tellico racing
Is that because it sits while you work on it? Or is it drivable now?
Old Apr 27, 2005 | 12:38 PM
proeliator's Avatar
proeliator
Look at his recent pic in the soty/coty thread and you'll know
I belieive I'm running 24/21 in mine.
Old Apr 27, 2005 | 12:48 PM
ivanribic's Avatar
ivanribic
[INSERT TECH]44" Swampers do a really great job of propping up a BBQ. Additionally, if you lay it on its side and throw a trash bag or some other liner in the wheel you can fill it with ice and throw a few drinks in there. The advantage is if someone falls while they're reaching for a beer the Swamper's soft compound will break their fall nicely.[/TECH]
Old Apr 27, 2005 | 12:58 PM
fishmanndotcom's Avatar
fishmanndotcom
20 up front and 18 out back.... they still look funny and wear on the inside but then again its been in the garage for most of the past year!
-cutts-
Old Apr 27, 2005 | 01:15 PM
tellico racing
Holy crap!!!
Ivan, How do you ever find time to work on the truck? I see your post count is higher than pro's........you have only been here a year and a half, You must have a puter out next to the truck or something.
I run my rear boggers at 14 or so, and the front gumbos at around 20 for mud.
In the sand I like to lower the pressure until the sidewall wrinkles, About 14 in the front and 11 in the back.....but that was with some other 38's I had, I haven't had the boggers on the dunes yet.
Old Apr 27, 2005 | 01:30 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
44" Ground Hawgs:
-30 in front
-20 in rear
49" Iroks
-22 front
-15 in rear
Then again you have to think, my truck weighs 9,200 lbs and 70% of that weight is over the front tires. Darn diesels.
Cody
Old Apr 27, 2005 | 02:09 PM
Momudder720's Avatar
Momudder720
Are you just runnin the Hawgs now Cody?
Old Apr 27, 2005 | 04:28 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yeah. I've got those spare donuts on there now. Good thing I kept them!!! They look STOO-PUD on there; they're too small (the bottom seam of the body sits 2" above the tops of the tires). But I've got a few driveshaft issues to iron out before I can put my 265/75's on there and run it down the highwayat a respectable speed.
With the way it's setup, I can do 45 MPH with the 265's, 67 MPH with the 44's and 74 with the 49's. My rear driveshaft RPM is limited to 2000 RPM due to angularity differences between the t-case and rear axle u-joints. I've got to turn my rear pinion up 3.5 degrees and put in a CV on the t-case end. Then I'll be good to 80 or so with the 265's. Not 80 or so with the 44's or 49's though. THAT would be stoo-pud.
Cody
Old Apr 27, 2005 | 05:02 PM
monsterbaby's Avatar
monsterbaby
hmmm my swampers are 4 yrs old and still have the mold parting line on them and they aren't sitting on the patio either then again the new boggers I got already are missing every other lug<a href='http://www.smileycentral.com/?partner=ZSzeb008_ZNxdm824BCUS' target='_blank'><img src='http://smileys.smileycentral.com/cat/36/36_6_2.gif' alt='Cigar' border=0></a>
but for preasures I run 20 front 14 rear
Old Apr 27, 2005 | 06:43 PM
teds74ford's Avatar
teds74ford
I had about 18 in all mine, but for street driving, I am running 30. They seem to handle better Mine also are lasting, but that is probably due to the fact that I have only put about 600 miles on them in the past 2 years. Working on stuff really increases the longevity of swampers
Old Apr 27, 2005 | 08:45 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i run 19 in the front and 17 in the back of mine....for some reason mine wear in the middle if i run them more than that
