supercharger
Old Apr 26, 2005 | 11:54 PM
Drover's Avatar
Drover
supercharger
Anyone been there ,done that??Be one low rpm terror!!
Old Apr 27, 2005 | 10:18 AM
Spectramac's Avatar
Spectramac
Lots of talk, but I haven't seen one yet. There really isn't much room for one under the hood, and there are already too many belts flopping around as it is.
Old Apr 27, 2005 | 11:20 AM
toyrobotus's Avatar
toyrobotus
Are we talking about an IDI motor with a GMC 6-71 or 8-71 blower setup? If I were to try it I would grab a late 6.9 block and look for some forged pistons that could be milled on top to lower compression. I guess that you would want to o-ring the head but then again I'm not sure that you couldnt get by on just the gasket, it may just be an "every 5 thousand mile" routine. Jeez, Im halfway through the first rebuild and Im already thinking about the next one....How about a serpentine setup with a blower through the hood of an F350. Would it have to go to direct injection though?
Old Apr 27, 2005 | 01:18 PM
Drover's Avatar
Drover
with the idi you could fab a blower intake from a stock set-up,other than running the fuel lines a bit different and changing from the cdr to a rdt.i agree about the belt issue. have to rethink that one a bit.as for space,who would,'t want a big polished 6-71 sticking thru the hood.if the boost levels are no more than a turbo would lower comp/o-ringed heads be nesassary??clacking and blower whine,yehaa!
Old Apr 29, 2005 | 09:48 PM
Spectramac's Avatar
Spectramac
All I can say is, I hope you have more machines in your shop than I do!
Old Apr 30, 2005 | 03:38 AM
Drover's Avatar
Drover
all i got is imagination and a set of craftsman tools!!LOL!!
Old Apr 30, 2005 | 12:53 PM
Spectramac's Avatar
Spectramac
Oh boy! You got yer work cut out for ya then!
Old May 2, 2005 | 10:31 PM
nogo73's Avatar
nogo73
I was thinging like a vortech set up earlier but the companies I talked to said no way could I get the boost I wanted at a low rpm so I don't know what to tell ya..
may be if you had a really big pully on it it would work as long as the belt dont slip your good to go >>>>------------->
Old May 2, 2005 | 10:50 PM
Drover's Avatar
Drover
6-71 or 8-71 would probably build alot more boost than the vortech at low rpm's
Old May 2, 2005 | 11:05 PM
Spectramac's Avatar
Spectramac
Maybe, but where you gonna put it?
Old May 3, 2005 | 06:24 AM
nogo73's Avatar
nogo73
its kind hard to one of those on there with the ip in the way and no room for a big belt
Old May 3, 2005 | 09:35 AM
goodie350's Avatar
goodie350
if you could make it fit at least you wouldn't have any problem running bigger exaust pipes since you wouldn't have to squeeze them between the engine and firewall.
Old May 4, 2005 | 03:15 AM
willd's Avatar
willd
I thought about a centrifugal, but you still have only top-end. Then I just ponied up and bought an ats setup on ebay for less than $600. I'll get it freshened up someday and put it on.
Old May 4, 2005 | 08:25 PM
soupy264's Avatar
soupy264
the 6-71 for a six-cyl,and the 8 -71 is for an 8 cyl. you probably want to check the out put for each,and the rpm restriction if any. they both run at 2100 max rpm on the detroits good luck Phil
Old May 4, 2005 | 08:59 PM
1984 f-250's Avatar
1984 f-250
You can get the electric ones for around 60 dollars
