SO, i would leave the ign off and would find a dead batt when I returned. I followed wires (with a diagram from autozone) and found that the alternator housing has a POSITIVE CHARGE ALWAYS, even with ign turned off. dug a little deeper and found the orange wire on the alternator (which the diagram says goes to the regulator) is the charged wire. SO. Is this wire always supposed to be charged, and the alternator's leaking? or is it NOT supposed to be charged and the regulator's leakin? or, is there another culprit? thanks!
"the alternator housing has a POSITIVE CHARGE ALWAYS"
[QUOTE=beartracks]The positive big wire on the alternator is hot all the time. The case should be ground potential
so the alternator housing should be 12 volts positive , which is connected to its brackets, which are connected to the engine, which is connected to the negative side of the battery......that seems odd
That wire is hot all the time. The alternator case should NOT ever be hot. Something fried inside the alternator. At a minimum, take the alternator to the parts house and have it tested. And when you replace it, consider replacing the voltage regulator also. I always replace both just as a precaution.
It's not the big wire that should always be hot. Its a smaller one that goes to the regulator, but i guess that it should also always be hot. I think i'll be able to go get it tested tomarrow. I'll let yall know.
I exchanged alternators today, and it still does the same exact thing. something that occured to me though was that the alternator is a 74 alternator, and the regulator is of the 76. Maybe they're incompatible?
Here's where i'm at. This is all with the ignition off (and even unplugged right now) :
Chasis has positive charge.
Orange wire running from insulated connection on the alternator to the "F" terminal on the regulator always has power.
Unplug the orange wire at alternator and there's no charge running through chasis or alternator housing.
there's no chance that regulators are interchangable between these years is there? (I noticed the internals look different, but would the 74 regulator solve my problems?)
Try taking the + cable off and putting a test light between the + cable and the + post and see if it lights up. Make sure anything that is hot all the time clock, etc. is disconnected.
Alright, I got it fixed. The regulator ended up being fried. Thanks for the help guys.
Oh, and the VR in this truck with duraspark is quite different than what was in my other one with points. If you open them up, they're very different setups.
Is it because one VR is mechanical and the other is solid state?
